OVERHEATING AFTER WATER PUMP REPLACEMENT
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Nov 11, 2019.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    My car was going through a lot of coolant before and seemed like the water pump was bad so we replaced it and all was good for a while. Then recently the overheating light started flashing again and will stay solid for a few seconds if I don't slow down or pull over quickly. It's going through coolant really fast again. Idk what the problem is. Looks like coolant is everywhere when I look around the reservoir but I can't tell where it's coming from. Before the water pump replacement I had misfire codes here and there also, even after replacing coils and plugs. There was a water pump code before the replacement. Now no codes pop.
  2. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    What mileage? Have you replaced the thermostat? Done an EGR system cleaning?
    Pixel XL ?
  3. Allison Meggison
    71
    El cajon
    it has 252k miles and no I haven't replaced the thermostat but it was blowing a lot of steam today when I pulled off the interstate after the warning light started flashing. I replaced the cap and the warning light didn't come on for a few hours. Now idk what the problem could be. I don't think I have done the EGR system cleaning.
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Anytime you replace the water pump, you should replace the thermostat.
    But it sound like you have a blown head gasket since you state you have steam blowing.
    Depending on where the gasket gives out, the exhaust will blow the coolant back to the overflow tank.
    Had a ford aerostar that did that.
    mjoo likes this.
  5. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Steam in the ICE machine is not good.
    How long have you owned the vehicle? How many miles have you put on her?
  6. bisco
    52,904
    maybe you didn't get all the air out
    mjoo likes this.
  7. Allison Meggison
    71
    El cajon
    I've had the car a little over a year and I've put about 70k miles on her. She blows steam from the overflow spout on the coolant reservoir near the cap and there's always coolant everywhere but idk where it's coming from. What's the best way to find out where it's coming from? Couldn't I use something to help detect the spot its leaking from?
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    What are you replacing the lost coolant with, toyota SLLC or something else?
    Which OBD2 scanner are you using to retrieve stored DTCs?
    m.wynn and Raytheeagle like this.
  9. Greenteapri
    330
    388
    Cypress
    When in doubt, rev up your engines!
    dig4dirt likes this.
  10. Allison Meggison
    71
    El cajon
    No I was bad and used water a couple times and last time I got the coolant from Auto zone they told me what was best but I haven't gotten it from the dealership in probably five months. I'm using the cheapest scanner tool that you get from walmart that costs $13. It's a tiny little red scanner.
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Water will lower the boiling point.
    A cheap scanner may not pick up all of the codes that are stored.
    m.wynn likes this.
  12. Allison Meggison
    71
    El cajon
    Dang I clicked on those links about oxyclean idk how to even get to the point of cleaning it with oxyclean. How do i know if the thermostat should be replaced? Should I try cleaning it first?
    mjoo likes this.
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    At your mileage I would just replace it with a new OEM part. They're around $40
    If you're not getting coolant out the exhaust or misfire codes - a thermostat and EGR cleanse may be all you need.
    Pixel XL ?
    m.wynn likes this.
  14. Allison Meggison
    71
    El cajon
    What is Pixie XL" lol I'm not sure. What is the best way to clean the EGR
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    @Raytheeagle would say pressure washer.
    Pixel XL ?
    m.wynn likes this.
  16. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I think it's a phone that he's using to reply on the forum with, and it auto creates a signature. Like iPhones used to do in emails.
    mjoo and Raytheeagle like this.
  17. Maximay
    Maximay New Member
    You have a blow head gasket. Your coolant is leaking to the combustion chambers causing misfires. Then blowing out the tail pipe. Exhaust pipe. Need to get a used engine from a donor prius that was in a wreck with low mileage on engine. This happens a lot. And get 2013 and up so the oil ring issue of oil consumption should not surfice
