Overheating, radiator fan not working, and exclamation mark sign on HUD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Asim Jahangir, Jun 16, 2014.
  1. Asim Jahangir
    Asim Jahangir Junior Member
    34
    Drove about 10miles and checked the coolant level. Coolant remains full in both chambers. No warning light today. I'll drive longer tomorrow to test. Hopefully no more engine heating.
    Thanks for all ten help.
  2. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    I found this thread and your post "Patrick"
    I have a 2008 Prius which is doing the following. ICE runs alot even after intial warm up phase.
    All city or under 50mph driving scangauge temp hits 190fwt and to me runs a little hot. No warning dash light are activated. but still concern . I am going to check airflow issuess, but wondering what else should be checked like thermostat/waterpump/fans/etc
  3. NortTexSalv04Prius
    915
    115
    ps how to check radiator fan module?
  4. Patrick Wong
    18,210
    6,510
    The Prius engine thermostat opens at 82 degrees C which is 180 degrees F. In very hot ambient temps and heavy load conditions, it would not surprise me if the engine is running at 190 degrees F.
    To check the radiator fans, turn the air conditioner compressor on and make sure the fans are blowing air towards the engine.
    valde3 likes this.
  5. Prius RT
    Prius RT Member
    131
    Question:
    My inverter pump works(see turbulence).
    My radiator and inverter pump fluid level is near high.
    I feel my engine gets hot even after driving for 10 mins. I don't know how hot is normal after driving say 10 mins?
    I don't get any fault codes. I checked the radiator fluid soon after I stopped engine.
    In both instances I did this, a bit of radiator fluid (maybe 1 or 2 tablespoon) gushed out. The color of the fluid was pink. Is this normal? If radiator was not doing its job and engine was overheating, would it throw a fault code ?
  6. JC91006
    16,769
    8,567
    If the car is not throwing any codes, then you should assume all is normal. Yes the engine of a car gets very hot after you drive 10 minutes, that's perfectly normal behavior
    Prius RT likes this.
