Overheating
Discussion in 'Gen 2 Prius Technical Discussion' started by Benjamin13295, Aug 3, 2018.
  1. Benjamin13295
    Benjamin13295 Junior Member
    62
    Slovakia
    Recently been on a 500km holiday in my Prius and on my way home something bad happened, as I was going up hill the red triangle came on and on the screen it said “Problem” and the coolant label came on, I recently changed the inverter coolant pump and all the fluids in the inverter and the in engine, I left the car rest for a bit and turned the heat on and slowly went home. What happened should I be worried ? What should I do? Please help
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Sounds to me like the engine water pump quit working. Broken drive belt, maybe?
    ZeroDigit likes this.
  3. JC91006
    16,936
    8,647
    You probably didn't bleed the system properly and it's not completely full of coolant. When the radiator is cool, open the radiator cap and fill with coolant. I'm thinking you will need more than half a gallon of coolant.
    Do not fill the radiator reservoir, fill the radiator itself.
  4. Benjamin13295
    62
    Slovakia
    They replaced it in Toyota
    DLC82SV likes this.
  5. JC91006
    16,936
    8,647
    They may have not bleed the air out completely. The prius is especially hard to do properly. Either you use an airlift type tool or you have to bleed manually multiple times
    M in KC likes this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Many many posters complaining of after dealer repair overheat or hear gurgling sounds under the dash reflecting air still in the system. The
    dealer does not want to spend the time necessary to do a thorough job. Its a PIA to get the air out very time consuming you have to engage the CHRS motor periodically to get the air out either with techstream or by jumping the relay out..
    I dont recommend complete engine flush because of this.Just dump the rad a few times over a few months it really helps and you will not invoke airlock. The G2 is very easy on the engine coolant but very hard on the inverter coolant.
    M in KC, DLC82SV and ZeroDigit like this.
  7. Benjamin13295
    62
    Slovakia
    Could it also be the water pump? Maybe it failed, but there is nothing leaking
  8. Benjamin13295
    62
    Slovakia
    The ac is also not working at times, could it be something to do when with the overheating I experienced? Could it be the water pump ?
  9. JC91006
    16,936
    8,647
    The failure of the inverter pump will cause your symptoms and ac intermittent failure.
    DLC82SV likes this.
  10. Benjamin13295
    62
    Slovakia
    I replaced it about a month ago with fresh coolant
    DLC82SV likes this.
  11. JC91006
    16,936
    8,647
    Since you have replaced coolant on both the engine side and inverter side, there must be something wrong with that replacement. I can think of these possible problems
    1. Low coolant in radiator
    2. Inverter pump failed
    3. Water pump and/or belt failure
    DLC82SV and Patrick Wong like this.
  12. audiodave
    audiodave Active Member
    800
    272
    US
    DLC82SV likes this.
  13. Benjamin13295
    62
    Slovakia
    DLC82SV likes this.
  14. Benjamin13295
    62
    Slovakia
    It’s probably the water pump in the engine , but there is no leaks
  15. JC91006
    16,936
    8,647
    It takes about a minute to check those 3 items I've mentioned. Just fill up the coolant if it's low, probably just wasn't bled properly
    DLC82SV, Patrick Wong and Raytheeagle like this.
  16. Benjamin13295
    62
    Slovakia
    Ohh ok thank you :)
  17. Benjamin13295
    62
    Slovakia
  18. Benjamin13295
    62
    Slovakia
    Checked the coolant in the engine and it’s low , where did it go ? :D I think I found the reason for the overheating
    DLC82SV likes this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Definitely looks low:(.
    Time to add some coolant;).
    Refilling a Gen2 requires patience, so be ready to add a bit:cool:.
    Good luck and keep us posted (y).
    DLC82SV and Benjamin13295 like this.
  20. Benjamin13295
    62
    Slovakia
    It’s weird you because it been in the Toyota dealerships for coolant replacement and inverter pump replacement so there is probably a leak somewhere
    Raytheeagle likes this.
