Overly sensitive breaking when in reverse
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amm1978, Oct 12, 2012.
  1. amm1978
    amm1978 New Member
    I've noticed over the last year or so that when I put my car in reverse to back out of a parking space, occasionally, the break pedal will not fully depress - probably goes about halfway down - and the breaking becomes very sensitive. I cannot smoothly back out because the breaks keep catching. Once I've switched back to forward drive, the problem is resolved. Is this normal, something I'm doing wrong, or does it indicate a breaking problem that needs to be fixed? I'm sure the dealer will suggest all sorts of expensive diagnostics, so I want to be prepared before I get in there. Any suggestions would be appreciated.
    Spindifferent likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Rusty rotors. Need to perform derustification of rotors.
    TsKarma likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You mean braking and not breaking ! Expanding on edthefox5's comments, one way to clean the brake rotors is while doing normal stopping, shift to Neutral. This disengages the HV battery, disables the regen braking and forces the friction brakes to work. This action will help wipe the rotors clean. Do this a couple of times and your rotors should be cleaned.
  4. fuzzy1
    10,723
    I'm not convinced that this is related to rust. My 2010 Prius rotors were always much cleaner than my Subaru rotors, yet still displayed this anomaly a few times. The Subaru's pads actually do stick to the rotors, but 'break' off with a slight snap, leaving a rusty outline of the pad on the rotor, but never have this reverse sensitivity. If anything, its rust acts as a weak lubricant, requiring slightly increased pedal force until the rust is removed.
    I still have a suspicion that there might be unidentified quirks remaining in the touch-and-feel layer of the Prius braking system: less-than-seamless transitions from regen to friction mode, rare transient dropouts of the power assist or stroke simulator or something similar, and this infrequent reverse sensitivity right after startup.
    Nothing has caused me any concern about the basic underlying hydraulic braking system. It seems to work correctly. But while federal safety regulations allow power assist brakes to revert to old-fashioned manual brakes in case of power assist failure, many drivers have now lost (or never developed) the manual braking reflex of putting their full body weight into the brake pedal. So when the pedal feel changes, there are likely to be some operator errors.
    The 2012 hasn't displayed any similar behavior yet, but I haven't had it long enough for that to mean anything.
  5. Selzier
    Selzier Whee!
    148
    51
    amm1978,
    I'm not sure if this applies to other generations but have you ever heard of a whirring noise when you get close to your Prius? Almost like it's purring to see you?
    Well that sound is actually your regenerative brakes powering up so that they can be used right away. I've read that if you wait around for too long (say you're fiddling in your car, plugging in your phone, maybe plugging in a destination into your Nav, etc etc) the electronic braking mechanism may lose the power it primed earlier and you're stuck with pure friction braking which can be very very touchy. I've never experienced this myself so I can't speak from a first hand experience sort of situation but this is what I gather you may be experiencing.
  6. dsviv
    dsviv Member
    170
    Eastern PA
    This has happened to my 2010 Prius IV many times over the last 3½ years. It seems to happen when the car has been parked for a short period of time and then restarted and put in reverse. The brakes are fine when you park and suddenly then are ultra sensitive when in reverse. The slightest touch to the pedal and it shutters the car to a hard stop. I have found that if I bring the car to a full stop, turn it off and restart it it fixes the problem. There have been complaints from many 2010 Prius owners about the braking, but Toyota claims there isn't any problem. I don't agree.
  7. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    If the brake pedal is sensitive, and you can safely, take your foot completely off the brake pedal for a split second. When you reapply pressure, the pedal will feel normal. Remember that the brake pedal operates by wire, not by hydraulic feedback...
    That, or put some mobile oil on the breaks. (I couldn't resist using two of my favorite misused homophones).
  8. Mendel Leisk
    42,376
    I've had exactly the symptoms the OP describes: super touchy brakes, just at start-up, just once in a long while, only in reverse, and the behaviour stops as soon as you get out of reverse and get going.
    The first time it happened I was backing up in a parallel parking spot, and could have sworn I'd hit the guy behind me: I touched the brakes and came to a sudden, jolting stop.
    I don't think it's rusting brake brakes, because of the various descriptors in my first paragraph. Seems like a software and/or mechanical bug. Very infrequent occurence.
  9. Mauiman
    Mauiman Junior Member
    43
    I also haven't thought it was related to rust -- the only thing that has worked for me when the brakes are touchy in reverse gear is to stop the car when the brakes grab, shift into Park, remove my foot from the brake pedal, then press the brake pedal, place in Reverse gear and resume backing with no further problem (until the next infrequent time this happens). I've tried placing the car in neutral when moving and using the brake to stop and cleaning the rotors like that hasn't stopped the brakes from grabbing.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I think I might have actually made this happen one time. Before I powered up, I held the brake down very hard and pressed the power. Put in reverse, let off the brake, backed out of garage, and applied brake. The pedal because very hard and very touchy. That was just a few months ago and I have been meaning to try the experiment again but forget to do so... mental note, try experiment again.
  11. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Same symptoms with my 2010 Two. I aways thought that it was me applying too much pressure on the brake pedal.
    - Spindifferent
  12. mbartley
    mbartley Junior Member
    48
    LA County, CA
    I have a (March) 2010 trim level III/3.
    If I get in my parked car, step on the brake pedal, press the start button, keep my foot on the pedal, switch into reverse, and then ease off on the brakes to start backing up, I get the "sensitive brakes" problem. If, instead, I step on the brake pedal, press the start button, release the brake pedal, step on it again, switch into reverse, and then ease off on the brakes to start backing up, I don't get the "sensitive brakes" problem.
    I haven't experimented with this thoroughly enough to add "never" and "always" to the above sentences, but as far as I can tell that seems to be the pattern with my car.
  13. ksyolsen
    ksyolsen Junior Member
    66
    28
    Haslett, MI
    2013 Prius v wagon
    I experienced the same issue this evening. Although my car started moving backwards despite holding the brake pedal so I pressed more firmly and it did the same thing as described above.
    I had pressed the brake, started the car, decided I wasn’t ready, turned it off. Sat for a few minutes, then started back up and went into reverse and then it happened.
    hopefully it’s not a sign of a major brake issue and it’s just a quirk that is rare!
  14. ChapmanF
    19,056
    I've had the same quirk. I don't know, 3 or 4 times in the 9 years I've had the car. Definitely some logic quirk, not something mechanical. Resolves after going forward some.
    ksyolsen and fuzzy1 like this.
  15. fuzzy1
    10,723
    That was my feeling too, on the 2010 I drove for three years. Am not remembering it on the mid-cycle-refreshed 2012 that was kept almost a dozen years.
    ksyolsen likes this.
  16. Mendel Leisk
    42,376
    Ditto.
