Owner for a PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by horent135, Oct 5, 2016.
  1. horent135
    horent135 Junior Member
    44
    CA
    2014 Prius Plug-in
    Just got a 2014 White PiP with 25k miles. This is my first hybrid as well PiP. I'm enjoying it now...
    Question about Plug-in.. When charging, can I just unplug any time? Say if I only charge for 30mins, is there a process of unplugging or just yank the plug? I don't want to damage the system..
    priuskitty likes this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, yanking is fine.
  3. mrbigh
    3,686
    699
    Long Island, NY
    removing the charger wand at any time will not harm the vehicle built in charger
    #3 mrbigh, Oct 5, 2016
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    or the battery
  5. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    One little clarification, always have the charger plugged into the wall outlet before you connect or disconnect from the car.
  6. horent135
    44
    CA
    2014 Prius Plug-in
    Thanks for the replies! This would be plug at the charging stations.
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Why?
  8. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    When you depress the lever on the car plug to remove it, a switch inside signals the relay in the charging controller (the box near the source end of the cable) to open and remove power from the car plug. That's also the reason to remove the car plug first when interrupting a charge, since pulling the source plug will create an arc at the socket, causing damage that can accumulate.
  9. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Thank you ... you learn something everyday (y)
  10. bisco
    52,878
    congrats and welcome, all the best!(y)
