Oxygen sensor - collar around it??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by r0b_, Feb 12, 2011.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,013
    NJ-USA
    silly question, when you start TS, did you open the drop down menu at the top of the screen: Setup/VIM select - and choose your X-horse VCM? You have to do that before trying to connect.
    Yes, Torque should show Fuel Trim data (as well as A/F and O2 sensor data).
  2. Robert John
    Robert John Junior Member
    64
    Montreal, QC
    1. Yep, I use the drop-down menu for Setup/VIN select. Techsteam remains elusive, despite all the time I've put into trying to get it to work.
    2. Good to know Torque should read Fuel Trim Data & A/F. I changed Bank 1, Sensor 2 (02) a while back thanks to Torque specifying the ODBII code for it. Easy to change (compared to Bank 1, Senor 1).
    Thanks again!
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Here is a preinstalled version of techstream : https://blog.obdii365.com/2019/11/04/download-techstream-v12-vmware-for-vxdiag-toyota/
    Here is the workup for DTCs P0136 P0137 P0138 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip0136.pdf
    Carid has a thin walled socket for 13++, and a Denso A/F sensor for 136++, or the TRQ version for much less.
