Oxygen Sensor Replacing & CAT Shield
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Timexhiker, Apr 12, 2023.
  1. Timexhiker
    Timexhiker Junior Member
    Arizona
    I have a CAT shield on my 2005. Engine light on. Auto store told me it’s 02 Sensor going bad. Will CAT shield have to be removed to replace Sensor. Could any Auto Repair shop be able to do that? I live where no DEQ inspections are required. Small rural town with 2 Auto Repair Shops. Haven’t asked around yet.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Please post the OBD2 code(s) that they found.
    O2 sensors don't last forever, how many miles are on the current sensors or when were they last replaced?
    Never worked around a cat shield, but would assume that it needs removal to access either the upstream or downstream sensor.
  3. Timexhiker
    Arizona
    Original as far as I know @ 158K
  4. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    You or they will use a pry bar to pop the rivets and unscrew the bolts to remove shield to deal with O2 sensor... It doesn't take much effort if your pry bar is long enough.
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Getting up there, so quite possible. What were the OBD2 codes?
