Oxygen Sensor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BNecessary, Jan 1, 2019.
  1. BNecessary
    BNecessary New Member
    Kentucky
    Where are the oxygen sensors located at on a 07 Prius base model. Are they easy to replace or would you take them to a shop to get them to change them?
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    The search feature has been fixed and is currently working (again), you shouldn't have any problems finding pictures and various methods for extraction.
    The upper A/F sensor (before the cat) is somewhat buried and requires a fairly thin walled socket for removal, the lower oxygen sensor (after the cat) is easily accessed and one can use a standard socket for removal.
    How many miles on this prius?
    Raytheeagle likes this.
  3. JC91006
    16,936
    8,646
    Are you getting a code for a bad catalytic converter? P0420?
  4. BNecessary
    Kentucky
    Code 0171 and after the code it says O2 Max Volt
  5. BNecessary
    Kentucky
    almost 209000 miles on the Prius
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
