P&G or Hypermilers waste gas in traffic - true?
Discussion in 'Gen 3 Prius Fuel Economy' started by jhinsc, Dec 4, 2010.
  1. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Donee,
    You don't need to explain the why's to me - I get it, but I hope it's useful for others new to this forum. Like I said, hypermiling and P&G I agree with, and commend your efforts in doing so. However, in the example you stated, obviously the woman in the Caddy didn't know what you were up to, as is the case of 99% of drivers out there, and she attempted to go around. Going slowly down a hill if there is no traffic behind is one thing, but since she was coming up behind you and saw you going slow, what was she to think? It may have been obvious to you, but not to her. She wasn't expecting what you were doing, and therefore ended up using fuel more inefficiently to go around or past you. This is an example of what I'm talking about. Most drivers out there are inefficient drivers, and the actions of super-efficient drivers in traffic cause an otherwise inefficient driver to be even more inefficient. I'm not trying to determine right or wrong - just a thoughtful discussion on this topic.
  2. ETC(SS)
    7,164
    I think most hypermilers are concerned mostly with their own mileages and any gas saved or lost by others due to their antics is pretty minimal.
    Aggresive drivers are going to find ways to 'waste' gas regardless of whether or not there are pulse and gliders out there...
  3. bwilson4web
    16,217
    Perhaps you might consider using the approach of finite element analysis to model the drivers, vehicles and a set of roads. Then use a random number generator to adjust the mix of traffic and driver behaviors and inject a 'hypermiler.' Run several thousand simulations and report the results.
    Commonly called a Monte Carlo simulation, it has the advantage of allowing insights into the effects of the control variable on the population without having to do the 'impossible' experiment.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Even without P&G everyone goes around me. I choose to drive at or slightly above the speed limit, which apparently is too slow for most drivers. I had the same issue even before owning a Prius, although it didn't happen when I was younger driving a CRX.
    Tom
  5. mite66
    mite66 Junior Member
    36
    I understand the point made by jhinsc. Even before my Prius, I was driving with fuel economy techniques all the time but It happened very often, in dense traffic, that I raced my way when a light turned green so that more cars would be able to also catch the light before it turned red again. I could have accelerated quite slowly (as I usually do) to save my own fuel but then, because of my behavior, 3 or 4 more gas guzzlers would be burning fuel idling at the light.
    So yes, sometime, saving your fuel can mean wasting other's.
  6. jhinsc
    1,167
    259
    South Carolina
    Well there's not much you can do about other drivers who want to go faster, unless you're in the left lane blocking traffic. I typically stay within 5 mph of the speed limit just to avoid speeding tickets, as highway patrol has been on OT on the main road in my area to stop speeders, in their claim to reduce accidents. Somewhat true, but all they need to do is remove the bonehead drivers out there who don't pay attention when they're behind the wheel. Note I'm not advocating speeding!:rockon:
  7. jhinsc
    1,167
    259
    South Carolina
    Uhhh sure... I'll jump right on that......
  8. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Driving friendly and hypermiling DO go together.
    Not only do I go out of my way to let others pass, it intersections I often avoid stopping in the left lane if the driver behind is going to make a right turn.
    __________________________________________
    In many parts of the US, including Dallas the problem is not hypermilers but the 90% that insist on speeding 10mph over the posted limit, consider ALL LANES a passing lane (maybe the shoulder :eek:), and think no more than two car lengths ahead.
    Seriously, does anyone feel responsible for the bad driving of a tailgater exhibiting signs of ADD and anger management? ;)
  9. jhinsc
    1,167
    259
    South Carolina
    I think I've always driven sensibly, but with my new Prius I'm now more concious of it. This evening I observed a young driver in a jacked up truck gunning it and tailgating cars behind a line of at least a dozen cars that was slowly going faster than us drivers in the right lane. FYI - I was going slightly faster than the speed limit with eveyrone else in my lane so it's not like we were holding things up. Did this kid think he was going to push the cars in front out of the way? One driver moved over then the kid started pushing the next car in front - unbelievable - like he was going to get "there" any faster.:rolleyes:
  10. Tink
    Tink New Member
    59
    Just curious - nothing to go by as I only got my Prius yesterday and have about 40 miles on it: Could some of the tricks, like described below, be why the displayed mileage is slightly more optimistic than the calculated?
  11. Tink
    Tink New Member
    59
    To be clear - I'm not saying they don't improve mpg's; rather, that they may not improve as much as the computer thinks?:noidea:
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I doubt it but since I don't know why the indicated mpg is optimistic I cannot say for sure. I think it has to do with latency issues between what is happening mechanically and what the sensors and ECU sees. This becomes obvious when watching the instantaneous mpg reading on a Scangauge and the factory MFD. They rarely read exactly the same.
  13. Tideland Prius
    16,559
    I have no idea why it's so optimistic. Our 2005 Prius' MFD mpg readout is much closer to the calculated number.
