P lock abnormal ok in hot weather
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Mar 17, 2018.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I've been getting the P lock error in my Gen 2 for a while now but for whatever reason the car is perfectly fine in the blistering heat. Does anyone know why?
    52,757
    other than a weak 12v, i haven't got a clue.
  3. franken1313
    franken1313 Member
    216
    27
    US
    No the 12v is fine I've replaced it many times thinking I keep buying defective 12v batteries
  4. franken1313
    franken1313 Member
    216
    27
    US
    I replaced the transmission ecu and shift actuator
    I still have the P Lock problem..
  5. bisco
    52,757
    unfortunately, if you read the p lock threads, it is vexing even to toyota. some think a wiring issue, perhaps rodents.
  6. franken1313
    franken1313 Member
    216
    27
    US
    So most likely replace the wiring harness?
  7. bisco
    52,757
    i wouldn't want to recommend that unless it is determined to be the problem. it's a uge job.
  8. franken1313
    franken1313 Member
    216
    27
    US
    Is there a way around this? I've accepted the fact that this car is dead. So Now I'm wondering if it's possible to rip everything prius out and say put a ford transmission and engine in it and just not have a hybrid anymore. It sounds like more $ to do this but now I'm looking at it as a hobby project
  9. bisco
    52,757
    almost impossible. if you could do that, you could replace the wiring harness.
  10. franken1313
    franken1313 Member
    216
    27
    US
    What wiring harness is it exactly? What do I Google? Is it this one? Screenshot_2018-03-30-20-59-50.jpg
  11. Elektroingenieur
    2,515
    3,288
    Three Touring
    Assuming the symptom is DTC C2300 (ACT System Malfunction), with no other DTCs, the Repair Manual says to check connectors T4 and S1, the P CON MTR fuse, the P CON relay, and the wires connecting them. Is this the problem on your car, and have you done the step-by-step voltage, resistance, and other checks specified in the manual, preferably while the symptom exists?
    Glancing at the Electrical Wiring Diagram, I believe the wire harnesses involved are the Engine Wire and the Engine Room Main Wire, but I wouldn’t replace either of these before doing the checks described in the Repair Manual. If the problem is intermittent and temperature-dependent, it might well be a defective connector housing, terminal, fuse socket, relay socket, or relay; perhaps some metal part is changing shape as it warms and cools and not making a good contact.
    If you find a problem, you might be able to make a repair, rather than changing the harness; see Toyota’s Wire Harness Repair Manual (PDF) for details.
  12. franken1313
    franken1313 Member
    216
    27
    US
    Yes I have that code C2300 Actuator system malfunction plus
    P3102 Transmission control ecu. I replaced the transmission ecu and the shift accuator.
  13. Elektroingenieur
    2,515
    3,288
    Three Touring
    DTC P3102 should always be reported with a three-digit INF (information) code. Which one do you have?
    As @ChapmanF suggested to you in October, have you done the step-by-step troubleshooting procedures in the Repair Manual for the two DTCs?
    Also, see the hints at the start of the Diagnostic Trouble Code Chart pages in the Electronic Shift Lever System section, about C2300 and P3102 being detected together and the P CON MAIN fuse.
  14. franken1313
    franken1313 Member
    216
    27
    US
    Raytheeagle likes this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The INF codes can be read with Techstream software ;).
    Your scanner may not (or now appears will not) be able to glean the codes:(.
  16. Elektroingenieur
    2,515
    3,288
    Three Touring
    As @Raytheeagle notes, a third-party scan tool may not be able to collect all of the information available with a Toyota Techstream diagnostic system, or even Toyota’s older Intelligent Tester unit.
    Before getting a different scan tool, though, I’d suggest doing the troubleshooting procedures, starting with the one for C2300.
  17. franken1313
    franken1313 Member
    216
    27
    US
    Is this it?
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    That’s the cable ;).
    You got an old laptop to run it:whistle:?
  19. franken1313
    franken1313 Member
    216
    27
    US
    Only one with windows 8
  20. franken1313
    franken1313 Member
    216
    27
    US
    I'm just scared of human error. I'd rather let a scanner tell me what to do. It just seems easier and less of a headache.
