P lock abnormal ok in hot weather
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Mar 17, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Should work;).
    Id do some searching here and on google about making the setup work as there will be challenges:(.
    But where there’s a will, there’s a way:).
    Keep us posted (y).
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    Unfortunately, the scan tool can’t tell you how to fix the problem. Even a Toyota Techstream system can only report what has been stored in the car’s computers, which simply don’t have the circuits or programming required to identify the exact cause of many problems.
    This is why Toyota publishes detailed, step-by-step troubleshooting procedures in the Repair Manual. The scan tool gives you a head start, by telling you which procedures to follow, but to make an effective repair, you have to finish the job.
