"P" parking button by mistake
Discussion in 'Gen 3 Prius Technical Discussion' started by arkey, Dec 17, 2011.
  1. arkey
    arkey Junior Member
    UK
    I noticed by mistake that its possible to engage "P" at slow speeds (3-4 mph?)
    Even at slower speeds the experience and effect was scary, its not like an emergency brake or hand brake stop but like chaining a dog to a stationary hook while running.
    Electronic and mechanical wise, whats happening when you push the "P" parking button. And why the Prius engineers allowed to set engaged other than just absolute stationary?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Because they assume you wouldn't do something so stupid! ;)
    You can engage Park in a traditional automatic at any speed. You can select Reverse in a manual at any speed. Do you really want the Prius to be that numb that it takes over in every eventuality?
    There are some safeguards built in to stop you engaging Park on the Prius at higher speed though.
    It is not good to engage park when the vehicle is moving at ANY speed. I make sure I am completely stationary before engaging it - and never do when in traffic in case some idiot rear ends me.
    Not sure if it's the same in the Prius but in an automatic a locking mechanism is engaged into the gears somehow when you select Park and this can be bent, damaged or completely broken if you engage it at too high a speed or get hit hard from behind with it already engaged.
  3. arkey
    arkey Junior Member
    UK
    Yess :)
    its not mechanical but by wire so all inputs are already controlled by the prius computer anyway. So why not, an extra control to protect any damage "by mistake".
    There is already a speed protection control but I was just trying to figure out if there is any situation where that "7 mph" limit makes sense rather than "absolute 0 mph" for "Parking"
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Below 7 MPH there is no regen braking, only friction braking, in the case of brake failure, there would be no way to stop below 7 MPH. But you can punch it in Park.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I made that mistake once with my first Prius. Pushed the P button at 3 or 4 mph and it made a loud clunk and stopped rather suddenly. I haven't done it since! can't be real good for the drive train.
    But you can push the Park button at faster speeds and it will just go into N, immediately, and remain there until you select a gear. Whereas if you put the shift lever in N at higher speeds you need to hold it there for a second or so before it goes into N.
    We had a lot of discussion about the best and fastest way to get a Prius into N at highway speed due the reports of "stuck throttles" etc. As you probably know all of those reports were bogus but we did learn that pushing P was a good way to get into N quickly at speeds over 7 mph. It's perfectly safe to select P or hold it in N for a second at highway speed to prove to yourself that it works. I have done it several times.
  6. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    When you press "P" the Prius checks the output from the speed sensor. If there is significant output it will set "N" instead and beep at you.
    If there is not much output it will engage a solenoid that puts a "locked" gear, similar to an oil pump gear, into the drive train. It's on the large housing containing the electric motors and the planetary gearset, but it's external (so it's not too hard to replace).
    It can be broken but it's not common. Usually one episode of engaging it while moving is enough to "school" most drivers to be more careful. ;) I suspect most cases of breakage occur due to accident or towing of a car with it engaged.
    You will probably be wondering about "R" now, so no, selecting "R" while moving won't harm anything. If you're going slow as above the car will actually engage "R" (reverse driving of the electric motor MG2 - there is no gear grasshopper). The car will slow to a stop and then reverse. If you're going too fast it will engage "N" and beep at you. The transition from "slow to too fast" as defined above is a few MPH.
  7. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    How the heck do you push the parking button by accident?
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    By hoping to press Auto on the climate and getting it wrong. Done it once or twice myself but thankfully not at low speed.
  9. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Was going for the radio's Power button. Happened twice long time ago. Now I'm a bit more conscious about it.
  10. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I was driving and my wife was doing something and accidentally touched it or dropped something on it. Maybe she had been doing something with the mp3 player and dropped it as she was putting it back in the tray.
    The audible alerts (wife and car) plus the loss of power made me realize quickly that the car was in neutral.
  11. tumbleweed
    4,067
    690
    Eastern Oregon
    My dog stepped on mine.
  12. arkey
    arkey Junior Member
    UK
    Probably its more common than many people thought.. In my opinion the place of the "P" button is wrong, first of all its very close to the A/C controls. Well.. The whole console design is not flawless but this could be an other thread here anyway.
    After a tired day, when driving in a rush hour where you stop and start every ten meters, you don't drive very consciously, this is when I push "P" before stopping completely, it was very slow but shocking enough to scare everyone in the car :)
  13. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    If you only use Park when you are actually parking (ie not in traffic), then why bother with it at all? Why not stop, apply parking brake and switch off. The car is automatically put in Park when turned off.
    Job sorted.
  15. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    While technically true, most manual transmissions will lock you from reverse until the stick has been in first gear, so I think OP has a valid point.
  16. stevemcelroy
    873
    194
    Boulder, CO
    One of the tings that I really dislike about my 09 is that you have to use the darned touch screen for heat/ac and the radio. In every other car that I have owned once I got used to the controls I would not have even look to change things - it could be done by touch. I can not imagine mixing up the radio or ac button with the park button which is way larger and which you have to hit fairly hard. Perhaps it is that I have an 09, but I have driven my folks 2010 a few times and it never occurred that it would be a problem.
  17. David Beale
    5,963
    1,985
    Edmonton Alberta
    You can use the steering wheel controls for A/C (heating and cooling) and for the radio.
    For A/C, I just use the "auto" position. It's too frustrating to do otherwise.
  18. tumbleweed
    4,067
    690
    Eastern Oregon
    A lot of times I like to keep the car running (i.e. in Ready) after I stop. If I'm going to sit in it and listen to the radio, for example, while waiting for my girl friend. Then I might leave it in Park and Ready to keep from running the 12V battery down. I also have my door locks set up to lock/unlock when the car disengages/engages Park, so Park unlocks my doors after I stop.
    I think the P button in a good easy to reach position and it should be left where it is. Accidental engagement only happens to most of us once, as previously mentioned, and no one has reported any damage. If it ain't broke don't fix it.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Me too. I very rarely switch the car off in its 10 hour shift - that way it protects the 12v which would struggle to power all my accessory equipment for any length of time. I was just offering a suggestion to the op who appears to have issue with the placing of the Park button. Personally I don't and have only once or twice pressed it whilst driving.
  20. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    That's a whole new meaning to parking paw(l)
    2 people like this.
