P/S
Discussion in 'Gen 2 Prius Main Forum' started by Niceboy, Sep 27, 2020.
  1. Niceboy
    Niceboy New Member
    Nigerian
    ----UK----
    Hi
    My prius gen 2 2007 won't start 3 days ago, it's shown me p/s problem and beep sound for few second and the hv batteries relay turn on then off and it's doesn't shown battery level on the monitor/screen
    Pls. Any help?
    #1 Niceboy, Sep 27, 2020
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Do you have any OBD2 codes (DTCs) that you can share with us ?
    Where in the world is P/s ?
  3. Niceboy
    Niceboy New Member
    Nigerian
    ----UK----
    No
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Not sure how far away you are from Lagos, but I'm sure that @Dxta would be happy to read the OBD2 codes (DTCs) for you
    Otherwise you could consider finding an OBD2 bluetooth adapter and using an App like Dr Prius or Torque to read the codes (DTCs).
    The best in class OBD2 reader would be a "mini-vci cable" (U$15) and techstream (dealer technician software) on a windows device.
    Are there any warning lights on the dash? (red triangle, etc)
    If you don't have the owners manuals (in the glove box?) to help decode the warning lights on the dash, use this link for online PDFs : 2007 Toyota Prius Owners Manual and Warranty - Toyota Owners
  5. The Lizard King
    89
    56
    Nigeria huh? You know I get a lot of e-mails from your countrymen each and every single day...
  6. Mendel Leisk
    42,345
    Me too: what (or where?) is p/s??
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    On the multi-information display, there can be a “PS” warning indicator, for electric power steering. I suppose “P/S” could also mean “power source” or “power supply.”
    The car’s built-in warning lights and indicators are designed only to show that there is a problem, not what the problem is. Anyone repairing a Prius car should have access to a Toyota Techstream (Global Techstream, GTS) computer-based diagnostic system; its predecessor, the hand-held Intelligent Tester (Diagnostic Tester); or an equivalent—and the Repair Manual (more info).
    As @SFO kindly suggested, the next step is to check for DTCs stored in the car’s computers (electronic control units, ECUs). This really should be done using Techstream or an equivalent: generic OBD II scan tools made for engine and emissions diagnosis are typically designed to communicate only with an engine control module, not with the car’s other computers, such as the ECUs for the hybrid system and HV battery.
    PriusChat welcomes members from all over the world. @Niceboy hasn’t asked us for anything other than repair advice, so let’s give him the benefit of the doubt that he has no more connection with the criminal element of Nigeria than we have with that of the United States.
    Mendel Leisk and dolj like this.
  8. Niceboy
    Niceboy New Member
    Nigerian
    ----UK----
    Ok
    May be there problems is u but me is p/s problem not u
    Help me with what u known base on this!
  9. Niceboy
    Niceboy New Member
    Nigerian
    ----UK----
    Thank you for your concerned ❤️❤️❣️
    I solved my problem.
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Great news!
    Can you please tell us exactly what the problem was, and how or what solved it?
    valde3 likes this.
