P0101 but MAF tests okay (and I've cleaned it)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Phil Schuyler, Aug 23, 2022.
  1. Phil Schuyler
    Phil Schuyler Junior Member
    I
    CEL has been on for a while now. I've cleaned the MAF, with specific cleaner, a few times but CEL always comes back.
    I found a document that spelled out test values for the MAF sensor. I can't find it now but recall it tested both the MAF portion of the sensor as well as temperature. This checked out fine.
    I have an OBD2 reader with Torque app and the Intake Air Temp and Mass Air values are present and seem reasonable.
    Can anyone point me to more troubleshooting steps or other parameters to monitor on the Torque app?
    Thanks in advance.
  2. JC91006
    16,936
    8,647
    When this error comes up, you most likely need to replace the sensor. Used ones are fairly cheap and they work like new
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    What MAF readings do you get at what RPM under what load and at what engine temperature?
    Cold idle in park (1300 rpm) =? g/sec
    Hot idle in park (1000 rpm) = ? g/sec
    Gas pedal on floor (WOT) - hot engine
    - park- 2500 = ? g/sec
    WOT accel - hot engine @65-75 mph
    = ? g/sec?
  4. Phil Schuyler
    I
    Well I embarrassed to say that I had previously cleaned the wrong part of the sensor. I mistook the IAT bulb for the MAF portion.
    I cleaned the MAF plates and have driven for about 85 miles with no light. Not declaring victory yet but...
    mr_guy_mann likes this.
  5. mr_guy_mann
    4,111
    2,011
    NJ-USA
    Good find. Keep us updated as to how things go.
    Remember, the first step to learning anything is to realize what you don't know. Ignorance is merely the other side of the coin from knowledge.
