1. mattdhurley12
    mattdhurley12 New Member
    29
    El Dorado Hills CA
    Just got P0116 code and freeze frame data shows coolant temp was at 275 degrees. Live data now shows coolant temperature at 190. Anyone know what to make of this?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I would watch your 12 volt battery. the computers all run off the 12 volt line, and when it is low, they become erratic.
    5 years is a good long life for a car battery, if you get more symptoms, replace it.
    The Toyota replacement has a 84 month warranty. Amazon used to have a cheaper price, but not today.
    amazon.com/Optima-Batteries-8171-767-DS46B24R-YellowTop/dp/B006VFEJJQ
  3. Mendel Leisk
    41,925
    Just googled water boiling point in a pressure cooker: 250F. Maybe the sensor is going bad? Or aforementioned battery problem?
  4. mattdhurley12
    29
    El Dorado Hills CA
    Merged.
    Battery reads 12.78V with car off.
    Merged.
    I did remove the mounting bolts for the coolant tank to access low beams two days ago. Is there anything I could have disturbed in that area to cause this?
    #4 mattdhurley12, Mar 28, 2017
