P0136 - Oxygen Sensor Bank 1 sensor 2 malfunction
Discussion in 'Gen 3 Prius Technical Discussion' started by spiralhelix, Jun 19, 2019.
  1. spiralhelix
    spiralhelix Active Member
    255
    219
    Illinois
    CEL came on over the weekend returning code P0136. Trying to read through all the posts regarding it, I think I'm gonna go ahead and change out the sensor since it has 214k miles of use. Just hoping someone can confirm I will be ordering the correct part before dropping the money. Also, so I can work on it this weekend, I would prefer to either get one locally or order through amazon. Or should I just try and find the time to install next week and wait for the "dealer" part. Prices all seem the same, just shipping times.
    Thanks.
    Dealer O2 Sensor 89465-47080
    Amazon Denso O2 Sensor 234-4400
    Here is the live data of my commute home reading just that sensor:
  2. ThatDudeOrion
    ThatDudeOrion Member
    95
    87
    Central, NJ
    hey, you probs already knew this, but that's the downstream O2 sensor which isn't used for adjusting AFR, so if you wanted to consider a more budget friendly replacement or just trying to clean it, etc. I would feel better about using it in this position as opposed to the upstream sensor, which is what's used for fueling adjustments.
  3. spiralhelix
    255
    219
    Illinois
    Thanks! I didn’t realize it could be cleaned. Unfortunately I already ordered the amazon one and will be here tomorrow. Of course on my way home last night, the CEL turned off. Did another scan and that code is pending again.
    -Spiral
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Looking at your screenshot, it looks like the voltage drop off could be a brake down in the sensor. If it was mine, since the sensor has to be removed, and could be stubborn to get out, I’d replace it.
  5. spiralhelix
    255
    219
    Illinois
    I wasn’t completely sure if that was because it was purely inverter engine at that point. That’s where I was transitioning from one highway to another
    But either way, I’ll install the new one since I got it and it’s a pain to do just for a cleaning
    -Spiral
  6. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Although you are receiving a P0136, there is a chance that the issue is with the front A/F sensor and not the rear. Check the voltage for the front A/F sensor, if it is above 3.3V (biased lean) and your rear o2 sensor shows rich, the front sensor is your problem.
    One of the techs in a group I am part of, made a video explaining this issue in further detail. There is actually a TSB on this funky “issue” for some Toyota models.
    Also, since you experienced a HG failure, your front a/f sensor might be contaminated. Mine was.
    Toyota and many modern cars do use the rear o2 sensor for fuel trim correction, but only to a limited extent.
    Raytheeagle likes this.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I guess I was lucky, in that when my HG failed, the engine failed immediately after.
  8. spiralhelix
    255
    219
    Illinois
    Both things good to know. I had read about changing the front sensor from some other threads, so that is on the radar, but didn’t really wanna drop $260 for two sensors at once if just the rear was bad.
    I just went out and checked the exhaust manifold from the old engine and they did reuse both sensors. Hopefully they verified the front sensor was not covered in junk when they reinstalled it. When they installed the engine I asked them to verify the cat was in good shape and if they said it was and it fails in the “warranty” it would need to be on their dime. They agreed so I am assuming the cat is not our problem and just sensor issues.
    It didn’t arrive Friday like they said, so I wasn’t able to change it over the weekend, so I’ll just have to find time this week after work.
    -Spiral
    The Critic likes this.
  9. ThatDudeOrion
    95
    87
    Central, NJ
    Sorry I meant to reply to your post regarding the rear O2s being used for fuel trims.
    Really? I didn’t realize this was being done. I always heard about narrowband o2 sensors and their voltage switching behavior and how they are only reliable in a small spectrum of AFRs near stoich. Which i assumed the AFR would be well outside of this range post catalyst meaning they wouldn’t be very useful to factor in for fuel trims and basically just a binary switch to make sure the catalyst was working to stay Emissions compliant via standard OBD2 checking logic. I figured this was why you can see people delete or sim the rear O2 without much trouble. But then again, The most “modern” stuff I have personally tuned or been able to see the tuning tables for is some domestic SPFI stuff that’s like 20+ Years old now..... yikes!
  10. spiralhelix
    255
    219
    Illinois
    I thought I'd update this thread, unfortunately not for the better. Since June when I first posted, the CEL actually had turned off on it's own for about 3 weeks. When it turned back on, I replaced the downstream O2 sensor during my regular oil change since the car was already on the lift. The car seemed to actually drive a lot smoother for 1 day. Day 2, CEL came back on with P0136. Here is the slight interesting thing, my fuel economy, which usually averages 36 mpg, was improving. I started seeing 38, 39 and even 40 mpg average during my commute (all highway mind you). The CEL started to grate on me a bit, so I broke down and purchased the Air Fuel Sensor (upstream o2). Got it installed yesterday, which in itself was a PITA. Either my ratchets were too short making it difficult to get leverage, or my breaker bars were too long and couldn't get any movement. Eventually i figured out an angle and hand placement to knock it loose. With the old one out, I tested the leads according to page 1992 of the manual and got 2.4 Ω for HT/B, and got OL (greater than 10 kΩ) for HT/AF-, so does that mean the old one isn't bad?? Got the new one installed anyway, cleared the code, drove to the auto store to return the o2 sockets, Mother &$#*er the CEL came back on with a P0136 code. Just ran out and looked at the voltages again and the A/F was at 3.3v with some fluctuations, Fuel Trim was between 0 and -2%, but the downstream O2 is showing (zero) Volts (which after reading may be due to the CEL being on). Could I have destroyed the downstream sensor over the last couple months? I didn't think to test the sensor resistances until this morning.
    So my plan is to:
    Test Resistance of Heated Oxygen sensor (ht1b/b 11-16Ω, ht1b/e2 >10kΩ)
    Test Voltage of the Heated Oxygen sensor Harness (11-14v)
    Test Resistance of Air Fuel sensor again (ht/b 1.8-3.4Ω, ht/af >10kΩ)
    If those test accordingly, according to p2301, the only other things left would be exhaust leaks or EGR valve? Gawd I hope that's not the case. It's only been 24k on this "new" engine with supposedly cleaned EGR system (not sure I believe that Lexus actually did this). Thankfully, my old system has been cleaned and I can swap it in if i have to. Open to any other suggestions.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I thought that sensor 1 was the a/f ratio sensor, but that doesn’t make sense that you would get a code for sensor 2.
    However, I have seen aftermarket sensors, especially Bosch brand show bad right out of the box.
  12. spiralhelix
    255
    219
    Illinois
    the video above that The Critic posted did a good job explaining why the A/F sensor would lead to a downstream sensor thrown code. I don't know why i didn't take the time to actually test either of the new sensors, guess I was just being lazy or too much blind faith. Both the sensors are not labeled "toyota", but are Denso and were priced the same. So it just came down to easy shipping from Amazon vs waiting on a dealer. I'm not really looking forward to removing the underbody paneling again to get at the AF sensor just to test it.
    I think I'll try clearing the code and recording the live data on my drive home to see if/when it fails.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I wonder if it’s something odd, like a cracked manifold or pipe. Something so extremely weird and uncommon that it’s being overlooked?
    I used to manage store to store deliveries for a major parts store chain, and we had one van that came back from out of town runs with a misfire and C E L. Chevy 4.3 V6. Long story short, after cap and rotor, wires, plugs, then a distributor, they found a burned valve on cyl 2. It took a couple of hours on the highway for it to not seal right. The leasing company chose not to fix it. They replaced it with a Ram Promaster full-size. That was a turd on wheels.
  14. The Critic
    3,193
    2,333
    CA
    Which Denso part number did you use?
    The Denso catalog pulls the wrong part number.
    If you look up the sensor with the Toyota catalog by VIN and cross reference that number, it comes up with a different sensor than what the Denso catalog shows.
  15. spiralhelix
    255
    219
    Illinois
    well crap:
    The Heated O2 sensor for downstream was the one I posted above. 243-4400
    The air fuel sensor was 234-9090.
    double crap. Looks like I got the correct one for the downstream, but the air fuel should have been 234-9112. Guess that's what I get for trusting Amazon to tell me "this part fits your vehicle". Strangely enough, the 9090 was visually the same size and harness fit perfectly.
    I guess I'll try and order the 9112 instead. Thanks Critic!
    update: I guess the 9090 fits the 2015-2016 model years.
    Raytheeagle and The Critic like this.
  16. The Critic
    3,193
    2,333
    CA
    No problem.
    Which year is yours? By VIN, the Toyota catalog shows 89467-02070 (for mine) which x-ref’s to 234-9112.
    At the time, IIRC, Denso’s catalog incorrectly listed something else. But on rockauto’s site right now, it is correct.
    #16 The Critic, Sep 3, 2019
  17. spiralhelix
    255
    219
    Illinois
    2012. The toyota number on the part itself is 89467-62060. all the sites to plug in vin numbers are acting funky for me right now. I'll have to come back and check later.
  18. The Critic
    3,193
    2,333
    CA
    Most of those sites are junk and are not up to date. You might need to use the actual Toyota EPC to verify - so hopefully you have a bud at the dealer who can help you.
    Also, don’t forget to clear the learned fuel trims after installing the new sensor. Toyota does not have a function for this via scan tool so you will have to disconnect the 12v for a while.
    Brinabrina92 and Raytheeagle like this.
  19. spiralhelix
    255
    219
    Illinois
    could that contribute to the code coming back right away even if the sensors are working properly?
  20. The Critic
    3,193
    2,333
    CA
    Yes, but only if the previous sensor had already failed and was causing a lean or rich condition.
    But ymmv
