P0138 error and misfires?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by turbo5spd-prius, Sep 17, 2024.
  1. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    I just got a P0138 code with a CEL. Techstream says
    "Oxygen sensor circuit high voltage (bank 1 sensor 2)". The monitor test results are a little odd because it shows 5 misfire status fields for the 4 cylinder engine. You'd expect it to go from 0 to 3 or 1 to 4 but it goes 0 to 4. They showed:
    EWMA MISFIRE: 1
    MISFIRE RATE: 4
    EWMA MISFIRE1: 1
    MISFIRE RATE1: 5
    EWMA MISFIRE2: 0
    MISFIRE RATE2: 0
    EWMA MISFIRE3: 0
    MISFIRE RATE3: 2
    EWMA MISFIRE4: 0
    MISFIRE RATE4: 0
    I searched for this code here on the site but nothing was clear. Is this one still ambiguous or is there some clear way to approach it now? If there's an approach, what is it?
    The engine feels like normal to me so far so no obvious symptoms.The cat was stolen in 2020 so the downstream sensor is new.
    Thanks.
    #1 turbo5spd-prius, Sep 17, 2024
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Can you post a screenshot from Techstream with the error data?
    P0138.pdf
  3. turbo5spd-prius
    71
    United States
    Hey,
    For some reason the error cleared itself. I thought to screenshot but hoped copying the info on misfires would have been enough.
    Don't know if it was because of repeatedly starting and moving the car small amounts without running it long enough to heat the catalytic converter. Here's to hoping the error doesn't return.
  4. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    If you continually start the car and turn it off before it has a chance to do the first warm-up (it takes about 50 seconds) then, yeah, it runs rough on the next start-up.
  5. ChapmanF
    18,936
    I don't see any RATE0. You get RATE1 through RATE4, and also an overall RATE.
  6. turbo5spd-prius
    71
    United States
    This makes sense, I guess. I hoped the lack of "rate 0" meant just "rate" was overall.
    Thanks Dolj, I was hoping that guess about warming up was correct. I appreciate the thorough engineering of these cars but it's not always fun to work on them so I'd rather not need to.
