P0138 Gen2 630,000miles 320K on this engine.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Schenck, Oct 4, 2022.
  1. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    P3190
    A week ago, I ran out of gas unexpectedly ( I had calculated that if I was getting ~ 40mpg I would be able to drive 400miles before filling up, after all, a ten gallon tank plus one, Right?
    Well, at 365 it shut down. P0606 (ECM/PCM fault), P3190 (Poor engine performance), P0A0F (Engine failed to start).
    With a new Lithium HV Battery, I just shut off the A/C and drove it the 3 miles to a gas station, filled up, and I was off.
    Yesterday after some hard 80+mph driving codes returned . The only way to clear the code was to turn the car to accessory mode, clear it and then start it. So I Slowed down to a more reasonable 75 mph with cruise control and continued on my journey.
    When I got to the 4144 foot incline that I normally fly up at 75 mph, reaching the top with 65% Battery. I had to slow to 55 and the battery was at 38%. P0606, P0A80,P3190 ( note PA080 deteriorating battery pack when it’s a new lithium upgrade) , Despite going only 200 miles I was low on gas so I Added 8.4 gallons to the tank( maybe I didn’t fill up completely, a week ago?) and again continued for 100 miles to my destination.
    Two hours later I started my return trip. Stopping for dinner and gas 200 miles later where I
    added 3.9 gallons.
    2 miles from home 160
    miles later, P3190 , P0A0F, returns, this time with 1/4 tank remaining. I reset the code and continued home.
    So MAF? Fuel Pressure? What do you think?
    Is there a fuel pressure sensor? If not, what’s the best way to check that?
    Any other ideas, theories, diagnostics?
    iPhone ?
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Any updates, or step by step diagnostic hurdles?
  4. JbMech
    JbMech New Member
    Washington
    See your last post for my response on fuel pressure test. Let me know if you need more help.
