P0171 every 5 months
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 05_silver, Aug 31, 2023.
  1. 05_silver
    05_silver Junior Member
    17
    Virginia
    I cleaned the MAF sensor in accordance with the instructions here. The code then goes away for about 5 months. It goes away long enough for me to believe that the MAF sensor is at fault or needs cleaning but I am not entirely sure.
    I have even replaced the MAF sensor.
    I would like to know what this is without going down too many difficult rabbit holes if at all possible.
    One thought is that I am using a cheap air filter that is non-Toyota and I live off of a dirt road. Maybe the filter allows more in than the OEM? 95% of my driving is not on this dirt road so I am not 100% sure about that.
    Any ideas?
    Thanks.
  2. JC91006
    16,885
    8,621
    Try cleaning the throttle body
    05_silver likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,107
    2,008
    NJ-USA
    What scantool are you using? What brand of MAF sensor did you install?
    Here's a list of "known good" MAF readings for my 2006 under different operating conditions. How does your car compare?
    What are Short Term and Long Term Fuel Trim values? - at "hot idle" - (1000RPM), at 2000RPM, at steady 45mph cruise, and at faster speeds.
    What does the upstream Air/Fuel sensor voltage show at same conditions? Screenshot_20220825-002058.jpeg
  4. 05_silver
    17
    Virginia
    Wow, never saw this. I will go ahead and clean the TB then. I replaced it with an OEM MAF (Denso) I believe. Putting back the old MAF results in the same scenario so I know it is not that. I do not have a scan tool for this purpose. Honestly with 5 other different branded vehicles the need to buy new scan tools does add up. I appreciate the info and when I am positioned to purchase a scan tool or perhaps use existing hardware or software laying around I will check into it further since the freaking light just popped up again.
    Thanks!
  5. mr_guy_mann
    4,107
    2,008
    NJ-USA
    Some ECM (engine) data is covered by generic OBD2 protocols. Stuff like RPM, MAF, ECT, fuel trims, etc are pretty much "the same" for most any 1996 & newer car sold in the US.
    So if you already have some type of scantool, it should have OBD2 capability and be able to give you some engine data.
  6. Leadfoot J. McCoalroller
    8,188
    7,694
    Pennsylvania
    2018 Prius c
    Agreed. It's very likely that one of the tools you already own can read the basics out of a Toyota, and fortunately you only need basic fuel injection info to solve this one.
    You probably don't need to spend money until this car shows a hybrid-related code
  7. 05_silver
    17
    Virginia
    Thanks.
    I cleaned the throttle body but that didn't fix it. I am also noticing an audible exhaust misfire now. I am not sure if it is related.
    I will try additional scan tools but don't want to go down any rabbit holes.
    Ideas on next steps please along with scan tools to use?
    Thanks.
  8. 05_silver
    17
    Virginia
    Suggestions on app to use? I have Dr. Prius. I don't think that it is capable of anything besides spitting out codes and telling me whether or not my hybrid battery is bad unless I stand corrected.
    Would TorquePro work?
    Thanks.
  9. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Try Hybrid Assistant. The program has a Reporter application function that links all trip data into visual charts for analyzing the situation.
    Hybrid Assistant: Dashboard
    But for errors, it is better to have a specialized Techstream.
  10. mr_guy_mann
    4,107
    2,008
    NJ-USA
    Torque can work, as can CarScanner. Really almost any generic OBD2 (engine data) app that is compatible with your phone and connection device should get you basic engine data.
