P0171- I think I need to replace vacuum hoses.
Discussion in 'Generation 1 Prius Discussion' started by Byron Fury, Jul 1, 2021.
  1. Byron Fury
    Byron Fury New Member
    Los Angeles, Ca
    2002 Prius
    I
    Gen-1 2002
    Because I have a P0171 and have already replaced the Mass flow sensor, I assume I have a vacuum leak somewhere.
    I'd like to replace all the vacuum hoses but I'm not sure which or where they are.
    Can someone please help with a diagram, youtube video or something that will show me which are my vacuum hoses?
  2. dabard051
    dabard051 Tinkerer-in-Charge
    232
    84
    Rochester, NY USA
    2002 Prius
  3. Josey
    Josey Active Member
    287
    108
    Virginia
    2003 Prius
    There is a schematic vacuum diagram under the hood.
    Your typical mechanic (or auto parts store person) reading a P0171 will tell you that you need a new upstream O2 sensor. That is, of course, not necessarily the case, but frequently is. In other words, the normal assumption isn't a vacuum leak, but a bad sensor. Both assumptions are ... well, assumptions.
    Do you have a scantool with which you can get live data from your O2 sensors? P0171 just means that the upstream O2 sensor is getting abnormally low (lean = too much air) readings. It can come from vacuum leaks or a bad sensor. But it starts with getting some data.
    And as far as vacuum leaks go, don't count out the intake manifold.
  4. Byron Fury
    Los Angeles, Ca
    2002 Prius
    I
    I'm not sure if this is a problem. I doubt it because I've already replaced this once. Unless I got a bad part.
  5. Byron Fury
    Los Angeles, Ca
    2002 Prius
    I
    Hey thanks so much for that! I just plugged in my scan tool and it seems as if one of the oxygen sensors are acting normally but I'm not sure what the other one is doing. Does this look normal to you?
  6. Josey
    Josey Active Member
    287
    108
    Virginia
    2003 Prius
    There's nothing wring with an O2 sensor reading of .86, but it's not static. You would need to be able to graph it. The O2 sensor should be constantly bouncing up and down between about .1V and .9V
    I tried to post a pic, but it won't work. See: OXYGEN SENSORS: HOW TO DIAGNOSE & REPLACE
