P0171
Discussion in 'Gen 3 Prius Technical Discussion' started by Cap'n Steve, Dec 19, 2016.
  1. Cap'n Steve
    Cap'n Steve Junior Member
    33
    US
    Update. I gave up looking for a leak and took it to the shop. They found the fuel pump to be barely working. Also found both rear hubs really bad. Worth the diagnostic. RockAuto here I come.....again. Hopefully the fuel pump isn't too hard on a Prius.
    52,891
    someone just did one, right under the rear seat. pretty simple i think, an hour or two.
  3. Cap'n Steve
    33
    US
    That's good to hear. Looks like I can source a denso which I believe is OEM from a buddy of mine for under 500. I just feel like I'll be throwing good money after bad with this car. Womp. Wish me luck!
  4. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I'm gonna stick my neck out and say the fuel pump will solve your P0171. And for the price of the damn thing let's hope I'm right! The rear hubs are easy on the Gen3, too. If it matters to you, my experience with Gen 2 wheel bearings determined the Timkens to be identical to OEM, including containing Koyo bearings. If you can source these for ~$100 each, I'd go that route over any of the other aftermarket names. I can't guarantee the Timkens for Gen 3 will be as "OE" as the Gen 2 but I'd guess it is the case. If the fuel pump doesn't solve your lean condition, have a look at this excellent troubleshooting piece.
    Toyota Tech Feature: Diagnosing Today's Complex Electronics Systems - Page 3 of 3
  5. Cap'n Steve
    33
    US
  6. that's so Prius of you
    that's so Prius of you Junior Member
