P0171
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Feb 8, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    What is this error code for???
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    How did you come across this error code (tool or service)?
  3. franken1313
    franken1313 Member
    216
    27
    US
    OBD reader
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Just a generic reader from a parts shop or something like a bluetooth reader that displays on the phone?
    P0171 usually means that the air/fuel ratio is too lean.
    Were any other codes thrown besides P0171?
  5. franken1313
    franken1313 Member
    216
    27
    US
    Its a OBD reader I bought on ebay for around 5$ & it connects to my phone via Bluetooth.
    Air/fuel ratio ? So what do I replace?
    No other codes
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Only fault light that has been on was check engine light? If there really are no other codes then you either have to check life data to figure out where the problem is or just ques something. Maybe cleaning the mass air flow sensor would be a good way to go if it has not been cleaned for long time.
  7. franken1313
    franken1313 Member
    216
    27
    US
    What is life data?
  8. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Read on abou other threads where they look for throttle body ..maf sensor and many other parts that are related to figure this you have....
    Generic obd readers are not very good for hybrid
  9. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Live data.
  10. Patrick Wong
    18,210
    6,517
    Look for something letting unmetered air into the engine, downstream from the throttle body, like a loose PCV hose, a failing O-ring on the engine oil cap or oil dipstick, or a bad throttle body gasket. Clean the mass air flow sensor as previously suggested. If all of this is good, you might have a problem with a fuel injector being clogged.
    What is the odometer reading?
