P0171
Discussion in 'Gen 2 Prius Technical Discussion' started by Cometflash, Jun 5, 2021.
  1. Prius RT
    Prius RT Member
    131
    Well, I don't have p0171 any longer. Driven for 150 miles. Car drives smooth. Mpg is 45mpg 2-3mpg better after I replaced CAT. Valve cover gasket was replaced 6 months ago. As expected of high mileage Prius I top off oil (1 quart) between oil changes. There are no visible oil leaks.
    The bolt of the part below the maf was loose (maybe when I went there to replace MAF..bcoz i got p0171 right after). That's what the mechanic said and I think that was why I was getting p0171
  2. Prius RT
    Prius RT Member
    131
    Interesting 2 years no p,0171. Now got it again on a 110F day. The previous time I had it was also on a hot summer day .
    It's most definitely not a MAF sensor issue as I replaced it. Mechanic had also ruled out vacuum leak after smoke test Just clueless why all of a sudden on a hot day p0171 comes back after literally 2 years of no such code. Last time mechanic had said he had tightened some bolts near the air intake and then after that I had no p0171 for 2 years.
    Any ideas? I have reset it and driven 10 miles...so far no code & engine running smooth
    #42 Prius RT, Jun 18, 2025
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    So you're in Nevada with full emissions testing you have annual inspection?
  4. Prius RT
    Prius RT Member
    131
    Yes. Emission test passed a month ago.
    Why
  5. Tombukt2
    13,875
    2,521
    Durham NC
    I was just curious if you were under that kind of a gun I don't have emissions testing where I am so I can ride around the check engine light on for 5 years as long as it's not affecting my gas mileage in my personal finances no problem. Where you is not sooo much. Certainly interesting how it seems to corelate w heat
  6. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Replaced it with OEM or some aftermarket? What brand, if aftermarket?
    What are your fuel trim readings for long and short-term fuel trims?
    Brian1954 likes this.
  7. Prius RT
    Prius RT Member
    131
    OEM. Don't think that's the issue.
    Anyway, after battery reset, code has not come up for 50 miles. Maybe it was just a one-off random thing. Like I said, 1st time this code came after 2 years. Last time when it came a few times , I did smoke test..was all good. But mechanic did did mention some bolt at air intake was a bit loose and he tightened. After that code never came
    P0171- bank 1'system too lean for a predetermined period of time
  8. Prius RT
    Prius RT Member
    131
    Seems like a one-off issue. Driven 350+ miles now, and no p0171. Drives smooth.
