P0300, P0301 and P0302 error codes. 2013 Prius. Low mileage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vishketan, Dec 30, 2019.
  1. vishketan
    vishketan New Member
    Saratoga
    Hi
    My 2013 Prius has just under 20,000 miles on it. Has had regular oil changes and routine maintenance performed. Couple of days ago it started making a knocking noise along with some strong vibrations, and the check engine light came on. I suspected that the cylinders were misfiring and sure enough, the OBD reader shows error codes P0300, P0301, and P0302. I read through the forums extensively and some of the most common root causes for this problem seem to be defective spark plugs or ignition coils, or clogged EGR intake port. Given that the car has such low mileage these seem plausible but, somewhat improbable. However, I am open to suggestions.
    I did have a brief look and saw that rodents seem to have chewed through two wires (see attached pictures). One is black and one is yellow. Could this be related or is this a red-herring?
    Any help or suggestions for further probing are deeply appreciated.
    thanks
    IMG_0532.jpg IMG_0533.jpg IMG_0536.jpg IMG_0532.jpg IMG_0533.jpg IMG_0536.jpg
    RMB and bisco like this.
  2. vishketan
    Saratoga
    A couple of other points that I forgot to mention. I put the car in P and revved the engine. The misfiring seems to happen mostly at low RPMs and tends to disappear at higher RPMs. Also I checked the engine oil levels and it seems to be close to the upper mark. The coolant level seems to be within spec.
    RMB likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    I would work on the chewed wires first
    RMB likes this.
  4. JC91006
    16,482
    8,399
    Yes yes yes, the answer is the chewed wires
    RMB likes this.
  5. bisco
    49,478
    is that about 3,000 miles per year?
    Levi Gonzalez likes this.
  6. vishketan
    Saratoga
    Thanks for your suggestions. Indeed it was the chewed wires that were the problem. I removed the fuel injector connector, spliced in a new one and so far it seems to be doing OK.
    @bisco: yes we drive very little in general and in particular this car much less (our other car is an EV and we tend to drive it a bit more).
  7. ASRDogman
    ASRDogman Senior Member
    6,089
    3,273
    Those wires go to the fuel injector. It's NOT supplying fuel to that cylinder.
    You can take the plug off. Remove the connecters, and solder some short pieces of wire
    to splice the wired together. (black to black, yellow to yellow)
    That will probably solve your misfire problem.
    You should check ALL your wiring to make sure nothing else is chewed through.
    NutzAboutBolts and Grit like this.
  8. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    Yes. And I've found it helpful to make friends with the neighborhood cat.
    dig4dirt likes this.
