P0301 Code + oil high/smeared on 1 side of dipstick??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by woody23, May 8, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    7,606
    3,915
    Butttt, you could have a failing head gasket also...
  2. Mendel Leisk
    41,509
    The spec'd plugs for gen 3, from my notes:
    spark plug: denso SC20HR11 (per Owner's Manual (toyota p/n: 90919-01253)<superceded by Denso SC16HR11 (hotter plug, revision by Toyota)
    I'd concur about the head gasket, gen 3, over 200k miles, code P0301, almost undoubtedly head gasket failure.
    woody23 likes this.
  3. woody23
    woody23 Junior Member
    69
    What's the definitive piece of evidence that it's the head gasket?
  4. woody23
    69
    It's been 3-4 weeks since that code and it's not come back.... Is that enough of an indication it's still the head gasket?
    I plan to get a rebuilt engine put it in soon. I'd just like to have an idea how much time I have to do it.
  5. ASRDogman
    7,606
    3,915
    I didn't say it WAS a head gasket..... It's possible.
    Has your coolant level gone down?
    Misfires and low coolant is a strong indication the head gasket has failed.
    It is possible it's just the bad spark plugs....
    Replace them with good ones, and if the misfires go away, you've found the issue.
    woody23 likes this.
  6. woody23
    69
    Coolant levels have not moved.
    ASRDogman likes this.
  7. Mendel Leisk
    41,509
    Not "definitive", but you've got a gen 3, it's got 206k miles, it's showing P0301, and you're getting shakes.
    Has the EGR ever been cleaned?
    woody23 likes this.
  8. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    Replace the plugs, clear the code, and go from there. It wouldn't hurt to look in the cylinders while you have the plugs out, but there's no reason to be trying to diagnose something else when you have spark plugs that look like that.
    (that being said, at 200k your head gasket is a ticking time bomb)
    woody23 and Brian1954 like this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    10,165
    6,319
    Texas Hill Country
    Bad plugs or coils will cause misfires all the time and not clear up after a startup rattle.
    It takes a series of misfires to set the code; most with early hg symptoms don't get a code and see no coolant change due to the small quantity of drops leaking into the cylinder for a short time.
    Wait long enough and it will rattle with an engine start after a stop light. Now you are risking a stranding when you blow a hole in the block. Then its replacement engine for sure and the options go from bad to expensive (used salvage yard, JDM used in Japan, Pro rebuilt with new pistons and rings).
    Dual view borescope on a cold engine with coolant pressurized can be definitive as can viewing steam cleaned piston(s).
    woody23 likes this.
  10. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Shortcuting cost like the Prius also eh? Counterfeit plugs everywhere.
    Real authentic plugs that will cost $20 more can go 120,000 and look a lot cleaner than your plugs. Sorry to pee in your Cheerios as a member here used to say.
  11. woody23
    69
    So since I replaced the plugs, the knock on start has been absent. The MPG has stayed depressed though at just 42mpg in the summer, down from 45-46 avg a year ago. P0301 has not yet returned but yesterday the check engine light came on while I was on the highway @ 70mph. It was P0101 this time. I felt like car didn't have the same power or thrust when the light came on. I've checked the MAF and it doesn't appear dirty.
  12. Eddie25
    497
    209
    MI
    I'd probably spray it with some MAF cleaner, unplug it and plug it back in, and do a visual of the the air filter plus look for any possible vacuum leaks. Clear the code, hit a non-busy highway, and see what happens. I'd also use my app to read the MAF and the fuel trims. That's just me. I wonder if you could get freeze frame data for the code?
    Have you done anything besides spark plugs or had anything removed or worked on recently?
    Brian1954 and woody23 like this.
  13. woody23
    69
    Nope, just the new plugs. I've got some of that cleaner so I'll do that today, and check for leaks, but what app are you referring to? I have the Dr. Prius app.
  14. Eddie25
    497
    209
    MI
    I use CarScanner for my iPhone. I used to use Torque (pro I think) with an Android (don't try Torque with an iphone).
    woody23 likes this.
