P0301 code with check engine light on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abu Rais, Nov 7, 2017.
  1. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Good eye. I just grabbed a pic from the internet, clear and big enough to reference the coolant reservoir. Probably euro/japanese right hand drive prius.
  2. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Here is the spark plugs after 197 K miles.
    Installed new shocks and struts.
    EGV cooler left with Oxy clean and purple cleane.
    It was very dirty Inside.
    Intake manifold gasket changed and cleaned. Lots of oil found inside and cleaned them all.
    Tomorrow will complete installing the OCC. and put everything back together.
    This morning before I took the car for to do all that, I had a hard time to start the car. Car wouldn't start with a check Hybrid System light on and wouldn't shift to D.
    Took out 12volt battery and tested at autozone. Battery tested 100% working. Came back home and installed the battery and tried to start the car and on a 2nd try it started. No more message on the dash. Drove 5 miles and stopped for Gas and same thing car wouldn't start. Luckily I had wrench so I unplugged positive treminal from the battery and put it back and car started. I drove then to the shop and stopped the car and Same problem.
    I called Hometown Hybrids and explained them the situations and the recommend to take the car at Dealership and check for Diagnostic code. Without any code they can't help.
    Plan is now to put back everything tomorrow and then drop the car at the dealership for full diagnosis.
    Any suggestions guys?
    I am doing my best to keep the car but rest is on God. Hoping for the best but this no stat is big headache. I think it's something electrical issue.
    mjoo likes this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The engine should run much better after cleaning your intake manifold and EGR cooler. Just give us a report after you're done.
    It takes around 3 hours to remove & reinstall the wiper cowl to get to the spark plugs. So while you're in there you might as well change the plugs. Also clean the PCV, MAP sensor and MAF sensor with MAF sensor cleaner.
    #23 mjoo, Nov 9, 2017
    Raytheeagle and Abu Rais like this.
  4. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Which one is MAP sensor and MAF sensor. I already installed a new PCV.
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    MAP is by throttle body. MAF is by the air filter
    Pixel XL ?
    Abu Rais likes this.
  6. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Found the MAF picture.
    Can you share one picture for MAP so I can find that to clean.
  7. Michael48
    Michael48 Junior Member
    26
    Seattle
    Did you figure this out?
  8. specul8tor
    specul8tor Junior Member
    My generation 3 Prius had a terrible engine rattle when I started it one day. It caused the check engine light to go on, and I drove it to AutoZone to get it diagnosed. The code was PO301 but and the person at AutoZone said it might just be a bad spark plug. I have 106 k miles on my 2010 Prius and have never changed the plugs. So I bought a set of four thinking I would change them all at the same time. After reading a little more about the rattling problem, I concluded it might have been due to starting the engine up and not letting it warm up, it had happened the day before when I moved the car out of the garage onto the driveway and back. I then thought the rattling and misfiring was due to that, so I erased the error code. It drives fine and has no issue. So before you do anything, I suggest erasing the code and seeing if it returns, it might be a real simple thing that set it off.
  9. JC91006
    16,933
    8,643
    I would treat the p0301 as a warning that something bad is in the near future. It's a misfire code. Erasing the code is like taking a 12 hour pain medication, which gives you short term relief.
    At 106k miles you are coming up on needed maintenance.
    Raytheeagle, RMB and NutzAboutBolts like this.
