P0301 mystery occurrence
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by goodMXguy, Feb 12, 2019.
  1. Tcortez
    Tcortez Junior Member
    25
    42
    Lancaster
    I was reading another post that someone removed the coolant cap o ring before cold start up and that helped with the shaking. I’m wondering if these thermostats get stuck and over heat the engine. I’m not losing any coolant or oil. I’m going to try and clean my egr and coolant circuit. I herd if you add water to the coolant it might cause a misfire also.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Removing the oring depressurizes the coolant system, meaning you won’t have coolant flow and will vaporize coolant. Adding water affects the performance of the coolant. It comes premixed and should only be adjusted in a spot;).
    Things to be aware of:).
    Good luck and keep us posted(y).
    Skibob and SFO like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Did you know most model T,s didn’t even have a water pump? Ever heard of a thermosyphin?
    Thermosiphon - Wikipedia
    Unfortunately it does not work so good with modern cars not designed this way
    It does make for old movies having radiators steaming though. The system was unpressurized.
