1. Justin Cummings
    Justin Cummings Junior Member
    Missouri
    2013 Prius 4. I cleaned the intake manifold, and replaced the gasket. I replaced the EGR valve and tried to clean the cooler, cleaned the EGR pipe to the IM. Oil looks good, No smoke, No fluid loss. Still getting P0301. Changed the spark plugs. Error went away and then came back. Shutters a low speed... you know "that" sound. Any ideas other than a head gasket?
    TIA
    Justin
  2. Mendel Leisk
    42,137
    What’s the miles?
    try swapping the coil/plug on cyl one with four, see if the code follows.
    once the head gasket starts letting go, all the EGR cleaning won’t turn back the clock.
  3. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Justin Cummings likes this.
  4. Justin Cummings
    Missouri
    Ok I'll try tomorrow and see. It has 253,000 miles :D
  5. Justin Cummings
    Missouri
    looks like I may be losing coolant afterall. I swapped the coil/plug on cyl one with four and the code went away, but there is a p0301 pending, so it's probably a blown head gasket. I used a borescope and looked at cylinder 1 and it was not steam cleaned. It had all carbon on it. it was all black.
  6. Brian1954
    Brian1954 Senior Member
    2,550
    1,009
    South Central PA, USA
    Look at cylinder #2 and tell us what you see.
  7. Brian1954
    2,550
    1,009
    Duplicate post.
  8. Justin Cummings
    Missouri
    I've already put it all back together. but I took it for another driver and got 0300,0301,0302
  9. Justin Cummings
    Missouri
    I don’t get it. This morning it is running like a new car no CEL. No death rattle, no shutter. WTH??
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,836
    6,802
    Texas Hill Country
    Typical of a head gasket. They start slow and sometimes can be weeks or even months between rattles. But its kind of like cancer, you have a chance the save the patient if aggressive work is done early. Later it will be engine time, which it may need anyway at 253k if any oil leaks or burns. New rings are recommended if you wait for an engine. A rebuilt head even with a simpler gasket job.
    Give it one more cold start rattle. Just don't use chemo, it will clog up your arteries.
