P0302 cylinder 2 misfire detected
Discussion in 'Gen 3 Prius Main Forum' started by Prsguy, Mar 16, 2022.
  1. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    You should look inside the cylinder and see if the piston is cleaner than the others.
    Maybe #1 cylinder is cleaner also? Do you see moisture in there?????
    Sounds like the begining of a failed head gasket....
  2. Mendel Leisk
    42,354
    Did you clean the EGR and intake (including the EGR passages in the latter)? At what miles?
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    The harness was my first thought, but odds of it being intermittent wouldn't be as likely.
  4. Mgoddard92
    Mgoddard92 Junior Member
    22
    Yes I cleaned the egr system and intake when I did the head gasket, so 2 weeks ago 198000 miles
    PriusCamper and Mendel Leisk like this.
  5. Mgoddard92
    22
    I just did head gasket and am hoping the short drive to town with a failing, mines spins a few hundred rpm above the targeted range, water pump didn’t blown a new gasket
    ASRDogman likes this.
  6. Mgoddard92
    22
    Well guys it looks like changing the #2 spark plug took care of the misfire.
  7. ASRDogman
    8,066
    4,089
    hope this resolves the problem permantly...
    #27 ASRDogman, Dec 31, 2022
    Mgoddard92 likes this.
