P0304, and no cause found
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Jan 27, 2019.
  1. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    The engine shutters at 1500 RPMs there's no check engine light lighting up but techstream software reveals a p0304 code. As we know this is a cylinder 4 misfire moving the coil pack from 4 to 3 and the plug from 4 to 2 and the injector from 4 to 1 clearing the codes and retesting it is still reveals the cylinder four misfire and it only happens at 1500 RPMs when the engine is warm not cold. Any knownknown causes? Cylinder compression test 175 PSI for all four cylinders. There is no antifreeze losas andthere'sno oil on the spark plug. And no there isn't any oil in the antifreeze either
    52,351
    ouch. 2010 with how many miles?
  3. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Too much carbon in the combustion chamber? EGR distribution problem (intake manifold EGR ports plugged)?
    Pixel XL ?
    m.wynn and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    It’s either fuel or air caused;).
    So if you’ve moved coils around and it still resides in cylinder 4, I’d look at the injector and intake manifold.
    Good luck and keep us posted (y).
    mjoo and m.wynn like this.
  5. douglasjre
    2,202
    736
    Null, NL
    Screenshots
  6. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Battery voltage is listed as 12.1V. Isn't that low?
    Pixel XL ?
