P0340 & P3100
Discussion in 'Generation 1 Prius Discussion' started by WHCSC, Sep 30, 2017.
  1. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I don't have access to the sub-codes. Is there anyone on here around Omaha that could get these for me? The P0340 should be simple and cheap enough to replace the camshaft sensor, but not sure where to start with the other one. Any thoughts?
    Zoljargal likes this.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    gotta have the sub codes, there are about 200 of them.
    P3100
    134
    HV ECU Internal Error
    135
    136
    GO Signal Error
    Open or short in GO signal circuit
    137
    Engine Speed Sensor Malfunction
    Engine speed sensor malfunction
    DTC NO.
    INF. Code
    Detection Item
    Detecting Condition
    P3100
    127
    IB Circuit Malfunction
    +B short in IB terminal circuit of HV ECU
    128
    Open or short in IB terminal circuit of HV ECU
    138
    When the difference between battery current of HV ECU and current of battery is large
    139
    IG Signal Circuit Malfunction
    HV ECU internal error
    140
    RAM Braked
    141
    ROM Braked
    142
    ST Signal Circuit Malfunction
    When ST signal of HV ECU is ON, with ignition switch turned OFF
    143
    Immobilizer Malfunction
    144
    Primary Check Malfunction
    145
    146
    147
    391
    Motor CPU Malfunction
    392
    393
    HV CPU Operation Malfunction
    148
    HV CPU Malfunction
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    Motor ECU Communication Circuit Malfunction
    160
    161
    Motor ECU Power Source Malfunction
    162
    163
    164
    165
    271
    Motor PWN Line Connection Malfunction
    166
    Motor R/D Malfunction
    167
    168
    169
    170
    DTC NO.
    INF. Code
    Detection Item
    Detecting Condition
    P3100
    171
    Motor REF Signal Malfunction
    172
    173
    174
    Motor Inverter Current Sensor Malfunction
    175
    176
    Motor Gate Shutdown Signal Line Connection Malfunction
    177
    Motor Main CPU Malfunction
    178
    179
    180
    Rotation Angle Check CPU Malfunction
    181
    182
    183
    184
    185
    186
    187
    Important RAM Malfunction
    188
    Generator CPU Malfunction
    189
    190
    191
    192
    193
    194
    195
    196
    310
    Generator PWN Line Connection Malfunction
    197
    Generator R/D Malfunction
    198
    199
    200
    201
    202
    203
    Generator Shutdown Signal Line Connection Malfunction
    390
    Charge Inhibition Control Malfunction
    WHCSC likes this.
  3. dolj
    dolj Senior Member
    8,588
    4,360
    Wellington, New Zealand
    As long as that is what the problem is. A sensor code does not mean the sensor failed, it could also be the plug, the wiring or the ECU.
    I just fixed a problem on a car (not a Prius) where the alternator light was illuminated on the dash. Did I just go out and replace the alternator? No. It turned out to be a break in one of the sense wires. Apart from my time, it was a free fix – but I already had all the tools and things to fix a broken wire. It only took 10-15 min to repair, but took several hours to diagnose and pinpoint the break, due to (in part) researching to get the wiring specs for that car and to understand the way the system works.
    WHCSC likes this.
  4. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Thanks. I know I may not need the new sensor. I just meant if that was the problem, it's an easy fix. Finding out what the problem is is the tough part. I'm looking into a mini vci. Any recommendations? Does the laptop have to be XP or can another OS work?
  5. dolj
    dolj Senior Member
    8,588
    4,360
    Yes, the laptop has to run windows either Win XP or Win 7 32-bit. You can use a laptop with another OS, as long as you have virtualisation software such as BootCamp, VMWare or Parallels e. g. on a Mac and run Win XP or Win 7 32-bit in the VM client.
    #5 dolj, Oct 1, 2017
    WHCSC likes this.
  6. Zoljargal
    Zoljargal Junior Member
    Mongolia
    2003 Prius
    Did you fix this problem. I have 2002 prius. I got that problem P0340 and P3100
    WHCSC likes this.
  7. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Just so people don't think I'm ignoring your question, it was also asked and answered in a private message. Good luck Zoljargal!
