P0343 code with a check hybrid system message?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chris777, Dec 27, 2023.
  1. Chris777
    Chris777 Guest
    Hello everyone so I had a check engine light with the code p0343 code as well as a check hybrid system, code. I replaced the camshaft sensor due to the P0343 code and now my car does not want to start when I reset my engine codes. My car starts for about three seconds then the engine codes come back on in the engine light as well and it also has the check hybrid system message. What is going on?So frustrating. The engine light and same p0343 code come back on after the obd engine code reset as well.i have a 2011 Prius
  2. Brian1954
    Brian1954 Senior Member
    2,688
    1,074
    South Central PA, USA
    What scanner are you using to read the trouble codes? I do not think that the scanner is capable of reading all the trouble codes that you have.
    The P0343 trouble code will turn on the Master Warning Light, but it will not turn on the check engine light, so you have other trouble codes that your scanner is not reading.
    Edit: FYI, your posts are moderated until you make 5 posts. This means that a moderator must read and approve your posts before it is visible on the site. So there is a delay (maybe up to 12 hours) between the time you respond and when it is visible for everyone to see.
    #2 Brian1954, Dec 27, 2023
  3. Chris777
    Chris777 Guest
    It’s a repair solutions 2 obd reader. The check hybrid message is also on. The car starts for a like 3 seconds then shuts off.
  4. Chris777
    Chris777 Guest
    I also had t mobile obd device scanner read the same code when I plugged that one in as well.
