P0401 code after cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by refusedone, Jul 25, 2022.
  1. Seymour1
    Seymour1 Member
    272
    36
  2. Seymour1
    Seymour1 Member
    272
    36
    Enging banging when turning ICE off.
    Maybe I should start a new thread, but my problem is close. I get the P0401 code and have cleaned the IM, EGR valve, cooler and pipes. I still got the P0401 code, but now after starting 6 times (no driving), there is a new problem; the engine bangs (like shaking a tin bucket with rocks in it). Also, when the engine is running, it surges up and down in speed. When cleaning the IM, I sprayed harsh chemicals (brake cleaner or carb cleaner) into IM while the MAP sensor was not removed. Others have posted about a spring and manget in the EGR valve. I did not notice a spring in mine. I cannot find a pic of the spring or where it goes.
  3. Mendel Leisk
    42,332
    Checking my record pics, see two springs. I believe that one lying on the paper drops on, then the cap:
    The rest of the batch attached:
  4. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    All I can tell you is I took mine apart and I was looking for the little ramp business and all this stuff that's supposed to break not work etc All I know is I could turn on those threads and the valve would open and close but when it was closed water still leak through one side to the other so it wasn't fully closed I put mine back together the car still shook did all the business I ordered a brand new one updated part etc etc still shakes acts up does whatever it's a lot better but still this is a replacement engine and a replacement transmission that both look a lot better than what I took out I have pretty much given up I fool around with the Persona every few weeks I started let it run put it in drive and floor it let the battery charge turn it off and leave it sitting pulling the engine out and all this stuff is not an option again I have four running generation twos that require none of these antics The car doesn't interest me that much I can just write it off to garbage basically everybody wants to come by and give me $2,000 for it with all the stuff that goes with it and says they can have it fixed in a few hours at some point I may let somebody give that a whirl just to see but I don't think so All this electronic control module changing and so on and so forth I have no reason to believe that this car needs any of that The codes reported are none and that's another kind of a kicker I have no misses no misfires no nothing engine running as smooth as glass even while the rattling is going on engines running perfectly there's no misses nothing oh well
  5. priusboi83702
    priusboi83702 New Member
    Boise
    Hi Seymour1- did you ever solve this issue? This seems exactly what’s happening to me right now (2010 with 195k miles) but I was careful to remove electrical components before getting messy with cleaners and degreasers.
    Mentally preparing myself to take it apart and clean again, but I’m not sure if I should just bite the bullet and throw a new EGR cooler and valve in….
    Any help is appreciated!
  6. Mendel Leisk
    42,332
    What all have you cleaned, and with what cleaners? What's the miles?
  7. priusboi83702
    Boise
    Hello there,
    2010 Prius with ~195k miles. I cleaned the EGR cooler, EGR pipe, EGR valve, and air intake manifold (including the EGR ports).
    I followed a combination of tips from videos by Nutz and Boltz and Mervs using the recommended cleaners from Mervs videos (purple power and easy off). Several days worth of soaking and rinsing for the EGR cooler. I didn’t have a pressure washer but plan to purchase one and get back into it this weekend to see if that’s the difference. I’m sure I didn’t get it as clean as some other folks have…. Hoping that’s the only lesson I need to learn.
    If this second cleaning doesn’t work I plan to replace the EGR valve first. If that doesn’t work then I’ll look into replacing the EGR cooler.
    Any advice is greatly appreciated, thank you!
  8. Mendel Leisk
    42,332
    Regarding EGR cooler cleaning:
    Concentrated lye solution will be most effective, for a heavily clogged cooler. The smaller end of the cooler is *21 mm ID IIRC, a #4 stopper is suitable, and propped in corner of laundry sink a cup of solution will fill it. Let bubble about an hour, rinse and repeat as needed.
    Read up on proper lye solution making, and use extreme caution with it. It’s only needed for the cooler, and is either detrimental or overkill for the rest.
    * will check later <confirmed
    #28 Mendel Leisk, Nov 5, 2025
  9. priusboi83702
    Boise
    Thanks for the help Mendel. The lye solution and enthusiastic use of a pressure washer made the cooler much cleaner. Intake manifold, pipe, and valve all looked clean and were not worked on. In this case it seems just the cooler was causing my issues.
    cheers.
