P0401 code - mechanic changed EGR - but still showing code - suspect catalytic converter (??)
Discussion in 'Gen 3 Prius Technical Discussion' started by priusth2010, Nov 16, 2022.
  1. priusth2010
    priusth2010 Junior Member
    Thailand
    Folks - not a mechanic here - so bear with me.
    Got a 2011 Prius 160Kish miles (250K Kms - if my math is right).
    1st visit
    Anyway - 2 weeks back got a Check-Engine light showing - brought the car into the mechanic > plug in the cable-thingy (TSC?) and the software show a P0401 code - meaning something to do with the "EGR"
    He suggested to change the EGR since it's very likely that the EGR is hose (cleaning it - which was the other option - will just be a waste of time - his word not mind).
    Anyway so I went through with his suggestion (btw the "new" replaced EGR was a second-hand part from salvaged prius)
    2nd visit
    Few days after, the check-engine engine light showed up again, brought in to the mechanic - same code (P0401) - the mechanic did few tests, this time he replaced the spark-plug AND another 2nd hand EGR > off I went.
    3rd visit
    4 days ago, noticed the car shuddered (quite violently) when starting it the first time in the morning, then the it went away after the battery/hybrid system kicks in - drives just fine afterwards; but just like that, again, the check-engine light showed up again - brought in to the mechanic, same code P0401. He suspected maybe it's takes time for the system to breaks in or get acclimated (?) - suggested me leave the car for longer period.
    4th & Final visit
    Brought it in for the longer check today - left it behind and well... they did some check and told me that they suspected it might be the catalytic converter??? (I highly suspected this - since code keep saying P0401).
    My Big Questions
    What do you folks think on them suspecting the cat-converter as the culprit? is it based? or is the mechanic just jumping into random conclusions? Anything that they might be missing?
    FYIss
    Note1- for all the times they changed the EGR - I wasn't there to look into what they did - it's just that they said they "replaced it".
    Note2 - on the shop - although they do got quite a bit of reputation for being the Prius Specialist in the city - but more or less it's still a very Mom & Pop operation - by that - I mean they would open the hood quickly - cling, clang, clung - done. Get the job done most of the times and fairly cheap compared to the dealers - but not sure on how good and thorough their triaging skill is.
  2. Mendel Leisk
    42,251
    That sounds like head gasket failing, allowing coolant to leak into cylinder. There's no misfire code, p030X (with X being 1 through 4, representing cylinder number)?
    Did your mechanic ever clean the intake manifold? It has crucial EGR passages, feeding the exhaust gasses to the engine intake ports. And yeah, it'd be good to see just how well they cleaned or replaced the other EGR components.
    There's a school-of-thought, and I subscribe to it, that the EGR clogging is what causes head gasket failures.
    donzoh1 likes this.
  3. Mr. F
    Mr. F Active Member
    389
    264
    Washington
    There are 4 key components in the EGR circuit: the intake manifold (not pictured), the EGR pipe (green), EGR valve assembly (blue), and EGR cooler (red). Each of these may get clogged over time, but can usually be cleaned out with a little effort without having to resort to replacement. Did your shop replace one or all of these components? Were the replacements cleaned out before they were installed? A blockage in any of the 4 components means there is effectively a blockage in the entire circuit—all of them need to be clean before installation.
    P0401 is set when the ECM opens and closes the EGR valve (for a test) during regular driving but sees a pressure change of less than 1 kPa. In order of decreasing likelihood, this can happen if:
    1. any of the 4 components above are clogged,
    2. the manifold absolute pressure sensor is malfunctioning, or
    3. the ECM is malfunctioning.
    The catalytic converter has nothing to do with this. As Mendel pointed out, if they replaced the entire EGR assembly (pipe+valve+cooler) but did not clean the EGR passages in the intake manifold, you would still end up with P0401.
  4. Mendel Leisk
    42,251
    Maybe. If the intake manifold EGR passage at cylinder one is near-totally carbon-clogged, BUT two through four are still flowing more, you might dodge the code, but still have one cylinder starved of exhaust gas. And the car’s computers none the wiser.
    Mr. F and CR94 like this.
  5. priusth2010
    Thailand
    Many thanks for the thorough replies folks!
    Tbh I'm not sure what they did, and their explanations didnt quite sink in with me (language issues too perhaps)
    Anyway, bringing it in to another shop and will make sure to run through the stuffs pointed out here with him.
    But to check again with you folks,
    Is there any likelihood that the catalytic converter might even be the culprit (as suggested by the original mechanic)??
  6. ChapmanF
    18,947
    No. The car's judgment of P0401 is made solely by opening the EGR valve and observing the effect on intake manifold pressure. If the pressure increase is too low, the EGR passages are judged to be clogged. The catalytic converter is not involved.
  7. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    I will offer at least one bit of advice. Unplug the egr valve electrical connector and allow the car to run in a non egr map until you get the egr system cleaned. The entire egr system needs a cleaning as its all clogged in varying amounts so that may eat you on labor cost and you may not think its worth it to mess with. But running the car with the system clogged like that is 100% testing the head gasket. You will get a failure if you keep the p0401 and keep going. For me a p0403 was better than a p0401 as the knock sensor threshold on these cars is too high and it really is bad for them (running the p0401 gives you a lot of knock, the p0403 gives you no knock). Maybe the unplugging of the egr valve electrical connector will stretch your dollar a bit further if you decide to run the car until it dies if you decide its not worth it to repair. I imagine the whole egr cleaning will be very expensive.
  8. ChapmanF
    18,947
    As long as the check-engine light is on with either a P0401 or P0403 code, you are already running with the fail-safe (non-EGR) parameters. The fail-safe chart specifies the same behavior for both codes.
    Just don't go unnecessarily clearing the code. Then you'd be running without the fail-safe protections, for as long as it takes the car to re-run the P0401 monitor and set the code again.
  9. Paladain55
    414
    172
    The South
    I would have to see that. i did forget i never actually got a p0401. p0403 runs great though. i would like to say clean it and run it or don't run it until you clean it.
    he says he has a p0401 and it runs like shit above so he better try unplugging it and saying a prayer to whatever god he believes in
    #9 Paladain55, Nov 17, 2022
  10. ChapmanF
    18,947
    But the mechanic has probably cleared codes with every "thereifixedit" attempt, so the car keeps not knowing it has a flow problem, until it runs the test again and finds out and redisplays the code.
    Paladain55 likes this.
  11. Paladain55
    414
    172
    The South
    wow! OP use your butt sensor. if you think the motor feels wrong, verify by unplugging the valve.
  12. Mr. F
    Mr. F Active Member
    389
    264
    Washington
    If P0401 is already set and the MIL is on, unplugging will additionally set P0403. I'm not sure how this would help.
  13. Paladain55
    414
    172
    The South
    Just so you get no chance of getting any EGR valve opening and I have seen the p0403 map runs fine. They could be the same though, but i wouldn't want to chance getting any egr at all until its cleaned.
    #13 Paladain55, Nov 17, 2022
  14. priusth2010
    Thailand
    Update #1:
    So brought the car into a new mechanic to have it checked.
    First Part:
    - Did a first TechStream test (See screenshot below) - same code: P0401 (along with all the readings -don't quite make sense to me; but attaching it here, just in case it gives any hint)
    - Check the EGR pipe, valve*** & cooler - parts look okay and fairly clean - since I'm assuming the other shops replaced it (*** more note on the EGR valve later on)
    - They took out the intake manifold and cleaned it (I was standing there while they took it apart and clean it) - it is bit gunk-ed up w/ oil; they also clean the throttle body
    Second Part:
    - Run the techstream test after the cleaning - got an "Incomplete" test (the head mechanic told me it was supposed to read "Normal")
    - Nonetheless, the mechanic gave the car a quick run 10 km w/ over 100Km/h - CEL show up again - brought it back to the garage
    Third Part:
    - Take out the old MAP Sensor and replaced it with a "new" one (Note-1: the old sensor have some oil at the bottom - see screenshot - not sure if it's bad or not) (Note-2: the "new" one was from another Prius unit - supposed to be working fine)
    - Techstream test still shows incomplete
    - Took apart the "EGR Valve" - there's this "spring thingy" not sure what it's called (see Pic-4 below); the mechanic showed me - in the other okay EGR, when you spin it in, it supposed to automatically spin out again (due to the spring); whereas the valve in my prius - it didn't quite move so smooth - there's a bit of stickiness to it.
    By the time we get to this - it was way too late in to put in the new EGR and test it; so plan is to have me drive the car out with the new MAP sensor over Sunday and see if the CEL will pop out again; and in any case, I'll bring the in again on Monday to be tested with the other EGR.
    Also another possible culprit could be the ECM
    But big questions as I was driving home:
    1) Is the spring thingy inside the EGR Valve supposed to spin out smoothly?
    Did the original mechanic actually put in a faulty EGR system and called it "replaced"??
    2) Also, just to look ahead - how likely is it that the ECM could be a culprit in this?
    how do I know that my ECM is faulty?
    Pictures:
    Pic1 - First TechStream Check
    Pic 2- Throttle Before being Cleaned
    Pic 3 - Old MAP Sensor Taken Out
    Pic-4 the EGR Valve (after taken apart) - the springy thing
  15. Paladain55
    414
    172
    The South
    it's definitely not the map sensor or the egr valve. But cleaning the valve is helpful and easy. p0401 means they did a shit job cleaning it. You will need to take it all apart again and clean and verify it's all clean again. Clean the EGR cooler until you can see through it. Don't play the games though. Games with the various levels of egr clogging only result in head gasket failure. I would imagine labor and kit is $2000 for that.
  16. Mr. F
    Mr. F Active Member
    389
    264
    Washington
    The exhaust gases enter the intake manifold through the port circled in blue, pass through the EGR gallery, which finally splits into four exit passages circled in red. When you pull the manifold off a high-mileage Prius you will usually find this entire circuit filled with carbon deposits. That is more important to clean (than the oil under the throttle body) if you're looking to clear up a P0401.
    Troubleshooting is a linear process—you point a finger at a possible trouble area, check whether it is functioning properly independently, and if it is, you move on the the next suspect. If you find a malfunctioning area, you fix it, check if the code went away, and your troubleshooting ends there. The suspects are usually lined up in order of increasing complexity, or in increasing order of the number of other systems they interact with. The very last trouble area is, therefore, usually the ECM (which is both highly complex and interacts with a lot of systems), and if you're left pointing a finger at it, you have to replace it. It is highly unlikely your ECM is bad.
    #16 Mr. F, Nov 19, 2022
    priusth2010, CR94 and Mendel Leisk like this.
  17. ChapmanF
    18,947
    The MAP sensor is what the car uses to confirm the EGR flow and decide when to say P0401. So it's not like checking the MAP sensor was an out-of-left-field idea. But there might be easier ways to check it than taking it out. If you just look at the MAP reading in Techstream, and it's around atmospheric pressure (14.7 psi or so) when the engine is off, and lower near 4 psi when idling, you'd pretty much say "MAP sensor's ok" and not bother taking it off and molesting it.
    An EGR valve with a mashed ski jump definitely can give you a persistent P0401. Look no further than the name of the thread where we first learned about mashed ski jumps:
    Still P0401 after cleaning egr !! should we drive it? | Page 3 | PriusChat
    The ski jump is a little stop you can see if you completely unscrew that rotor you find in there, and look up in the center of it:
    Compare one that has had a track mashed right through it:
    ozmatt managed to fix it by using a heated butter knife to smrsh the plastic back into shape, but that's pretty hardcore. It's easier to put in a new valve.
  18. priusth2010
    Thailand
    Yeap - they clean it, one of his crews flushed the chambers in the manifold - and I checked it after he's done
    Also as for other parts, the
    > Pipe: Looks fairly clean
    > Cooler: the crew took it apart and can see through it
    Now as with the Valve
    Yeah (at the end of the day) the new mechanic is fairly suspicious it could be the Valve - we tried spinning the black plastic thingy, and as mentioned mine does feel bit sticky, the other one (the known working one) have instant feedback -
    But we got to this point when it was way too late - so we just made a plan to bring the car in again on Monday to get it check.
    Will point out to him to check on the Ski-Jump part ....
    Actually found this video from this guy; he pointed the issues with the "magnet" part of the egr-valve too which just sounds eerily similiar to the sticky-ness issue that I encountered with my valve.
    link here:
    Anyway Thanks will keep you all posted -
  19. Mendel Leisk
    42,251
    In the video he's using a 10-32 x 3/4 machine screw. An imperial measure screw. I'd be real cautious with that. I'd suspect they're M5 screws, have purchased a few in advance, socket-head cap screw style.
    There's a couple of EGR valve part no's on this page:
    https://www.amayama.com/en/catalogs/toyota/prius/3-hatchback-right-xw30-2011-r-2828/engine-fuel-system-and-tools-1/exhaust-gas-recirculation-system-52
    25620-37110
    25620-37120
    There was a rev to the valve, guessing the second one is the rev'd version? It's the part number on the box in the video, fwiw.
    Anyway, just food for thought. See what the price is with shipping for you. When I view the page in Canada, for the second one (...37120) I see:
    So far for me, having made 4~5 purchases through them, item cost plus shipping is "all in", no extra charges, say taxes or duty.
    #19 Mendel Leisk, Nov 20, 2022
  20. ChapmanF
    18,947
    I just looked at that video. I noticed there was one misinformed commenter who made two comments on it, "That part you're calling a stepper motor is a solenoid coil" and "The magnet just threads on. Spinning is not part of its operation", both of which are the opposite of true. It is indeed a stepper motor, and spinning the rotor is indeed what opens and closes the valve.
    If I had a youtube account, I would add a comment there correcting that. Maybe somebody else can?
