P0401 Prius 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mike 777, Mar 24, 2016.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    From 2010 Repair Manual:
    DTC P0401:
    Exhaust Gas Recirculation - Flow Insufficient Detected
    - EGR valve assembly
    - EGR passage
    - EGR with cooler pipe subassembly
    - Manifold absolute pressure sensor
    DESCRIPTION
    The manifold absolute pressure sensor detects pressure inside the intake manifold as an absolute pressure with a
    built-in sensor and outputs a voltage. Based on the voltage from the manifold absolute pressure sensor, the
    ECM controls the EGR, purge VSV, and detects errors in the pressure sensor using the changes in pressure.
  2. Mike 777
    Mike 777 Junior Member
    16
    Los Angeles
    Do you know what kind of cleaner?
  3. Mendel Leisk
    42,293
    With your mileage the EGR cooler could very well be clogged. A few owners are reporting this. That's the component at the head of the circuit, connecting to the exhaust mainifold, and with 4 coolant lines.
