P0420 code after replacing catalytic converter, slightly overfilled oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tangerino, Apr 14, 2021.
  1. Mendel Leisk
    42,382
    The distance between the two indents on dipstick is 1.5 liters, or 1.6 US quarts (rounds to roughly 1.5 as well), noted in Owners Manual. Still not a lot of overfill.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    The "variable" for an exhaust leak is the gasket at the spring loaded manifold connection. It can seal at idle but leak when the powertrain moves under load. I have found that only a Toyota gasket will reliably seal any cat.
    That said, the P0420 cat test is run at idle, and likely fails because you have a cheap AM replacement cat. Less than 1 psi back pressure is "nearly nothing". Normal for most cars is under 2 psi when snapping the throttle fully open or when driving under high load.
    If A/F and O2 sensors work properly & fuel trims are 0 +/- 10%, then put another cat in.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    And you must use the factory donut not the one that came with the new cat. Here's the part number:
    As a sidenote my bought new 07 at 12 years later @150K miles started to use a very small amount of oil. 2 things I found stopped it. Move up to a 40 weight oil and overfill it about an 1/8th of an inch.
    And check the dipstick minimum once a week after it has sat overnight and before starting the car and never let it get below the full line.
    3 years later when I sold it it still did not any oil.
  4. Wonder
    Wonder Member
    87
    25
    Las Vegas
    2013 Prius Plug-in
    That is very interesting... I thought overfilling was bad in a way that puts extra pressure on the system, causes oil leaks (valve cover ect) and/or changes the viscosity (idk last one... too low oil changes the viscosity, pretty sure overfill doesn't.)
  5. Wonder
    Wonder Member
    87
    25
    Las Vegas
    2013 Prius Plug-in
    Do you know if this is mostly an issue for 2nd gen or if it also pertains to gen 3?
