P0420 Code only when there is less than half tank of fuel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Koich, Jul 3, 2025.
  1. Koich
    Koich New Member
    Bay Area
    Hello all. This is my first post.
    I searched the forum to look for similar symptoms, but couldn't find any.
    Because the CEL/P0420 only comes on after consuming more than half the tank of fuel, I'm assuming it's something tank-related. I learned that the Gen 2 Prius doesn't have an EGR valve, so assuming it's something else but fuel-related.
    My previous experience with Toyotas with similar problems was fixed with a new gas cap. Maybe I'll try this for the first shot.
    Has anyone experienced anything like this?
  2. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    Does the car have the original catalytic converter? How many miles on the car? Does your engine burn oil?
  3. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    ...and this CAT code goes away by itself when you fill up?
    Brian1954 and Tombukt2 like this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    The catalyst being below threshold is known to the car by it running a self test on the catalyst system at random times . Unknown times as far as I know . So maybe it runs this test right after you fill up with gas.? I have no idea I have nothing to refer to as to how the test works. I don't know of other things being wrong could fool the system into this particular code.
  5. Koich
    Koich New Member
    Bay Area
    It does not have it's original catalytic. About 221K miles on the car, and yes, it does burn oil, but that doesn't explain the CEL on/off with the fuel level.
    Sort of. The CEL goes away after 1 fuel bar is consumed, and comes back when only 3 or 4 fuel bars are left.
    That's an interesting theory.
    But if so, resetting when fueled doesn't make sense either?
    #5 Koich, Jul 9, 2025
  6. Tombukt2
    13,868
    2,520
    Durham NC
    That's not a theory that's what the car does that's how it knows to set that code what do you think it just makes it up?
  7. Koich
    Koich New Member
    Bay Area
    You're taking my comment the wrong way. ;)
    My Interesting theory comment was based on your comment of "So maybe it runs this test right after you fill up with gas.?" and respect to your knowledge. :)
  8. ChapmanF
    19,041
    The gen 3 repair manual says the test takes about 30 seconds to run and is done once per driving cycle, some time after the engine warms up.
    I don't have a gen 2 repair manual handy right now to look at, but I'd be surprised if it didn't also take the mystery out of when the test runs.
