P0A09 DC/DC CONVERTER STATUS CIRCUIT LOW INPUT
Discussion in 'Gen 2 Prius Main Forum' started by kinga, Feb 9, 2017.
  1. kinga
    kinga New Member
    London
    So I have been diagnosed with such a code with independent garage. Is that a major problem? I am very new to Prius.
    Any ideas how much that could cost me?
    Thank you
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Couple of questions;
    Did you take it to the garage because indicator lights appeared on your dash? (if yes and you remember, what were the indicators)
    Does the vehicle currently run or is it stuck at the garage?
    52,925
    welcome! how many miles on her?
  4. Patrick Wong
    18,214
    6,531
    This could mean that the inverter needs to be replaced. In that case you should have a used unit installed.
    Or it could mean that the wiring harness between the inverter and the hybrid vehicle ECU has a problem. This is possible if the car was in a front-end accident or suffered damage from rodent infestation.
  5. priuslover17
    priuslover17 New Member
    New York
    I
    Any good resources on how to check the wiring?
  6. DIYohWhy
    DIYohWhy Junior Member
    62
    Pennsylvania
    Did you ever figure it out and how to check wiring?
  7. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    You would physically as with you're eyes look from inverter thru firewall to the ECU near in the rack of ecu's looking for chew marks burnt wires crushed wires etc . An event has happened .
