P0A0F and P3190
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by awommy, Mar 31, 2016.
  1. Mrs.Diamond
    Mrs.Diamond Junior Member
    66
    Minneapolis, MN
    Is there a way to inexpensively fix this if that was the case?
  2. Erik Owens
    Erik Owens Member
    162
    59
    Has anyone checked on the TSB EG047-04
    SFO likes this.
  3. Erik Owens
    Erik Owens Member
    162
    59
    BTW I havent read any of this post at all. Just on auto pilot, sorry. Long day.
    SFO likes this.
  4. Mrs.Diamond
    66
    Minneapolis, MN
    No, I haven’t. My car with the issue is a 2006. Bought as a project car to learn on. I love learning and working on these cars. Yesterday I changed spark plugs. They were so gross I know oil dropped into everywhere it shouldn’t have. Need to do more reading and see if something else also needs to be changed. I got the oil out of the well before I pulled the plug and the car did start but still running this code. Need to dive into it more.
  5. Erik Owens
    Erik Owens Member
    162
    59
    Do yourself a favor, get some carb cleaner or brake clean solvent spray and check out that throttle body plate and make sure it is clean and nothing is wedged in the butterfly valve. I have found a spine of a leaf keeping it from actuating properly. Then make sure you have brake clean or MAF cleaner and get n LED flashlight or the brightest flashlight you can muster and shine it to where you can see the hot wire resistors of the maf and make sure they are clean and not fuzzy looking or something melted on there.
    I thought you said 2004 so that TSB doesnt apply sadly.
  6. Erik Owens
    Erik Owens Member
    162
    59
    Make sure the MAF is unplugged and be careful of those small screws. Rusted they suck getting out.
  7. Erik Owens
    Erik Owens Member
    162
    59
    And make sure you dont have any issues with your fuel being off on the gauge. You could be empty of fuel but if you have never had an issue then nix that idea. I would chase that P3190 which is POOR ENGINE POWER which identifies the sequential fuel injection system which is air induction (air box and throttle), fuel injector and fuel system, and MAF etc. Hope that helps but 9/10 times its just a disgusting throttle body. Also after cleaning remove the neg battery cable for 10 min or so to try and reset the fuel trims which I want to say you dont need a scan tool to do.
    Sometimes Im wrong on that one depending on year to year and model to model in Toyota land.
  8. Mrs.Diamond
    66
    Minneapolis, MN
    Thanks Erik, I did all of those steps yesterday as well. Need to rebuild the hybrid battery and drop in a different 12 volt and will resume work on the car on Friday. Thanks for all the input. The MAF was really dirty, removed it, cleaned it properly let it dry. Removed the air intake, cleaned the throttle body and butterfly, also put carb cleaner in. I think it needs more and some fuel injector cleaner in the fuel tank. Also another oil change as after driving the car 400 miles and it sitting for a week the oil was VERY dark again. My husband changed the oil the night we brought her home for me to tinker with. I think it had more maintenance at 260,000 and the poor car just got drove into the ground. She still had the original spark plugs.
  9. Mrs.Diamond
    66
    Minneapolis, MN
    I did invest in Techstream it’s just I’m still leaning how to read the live data. I love all the help. Thanks!
  10. Mrs.Diamond
    66
    Minneapolis, MN
    Fuel was 91 no ethanol as I knew she was needing some love and when I parked her I knew I might need her to idle In ready for a few hours to burn out the junk. I knew she need new batteries and that she was running like crap so I don’t think it’s a fuel gauge issue thankfully.
  11. Erik Owens
    Erik Owens Member
    162
    59
    Alright let me know if you need any more tips and what not. Ive been working on Hybrids for almost 3 years so Im still learning as well.
    Mrs.Diamond likes this.
  12. Mrs.Diamond
    66
    Minneapolis, MN
    I went a little crazy and bought 4 priuses. So I’ll likely be taking you up on that.
  13. Erik Owens
    Erik Owens Member
    162
    59
    You better.
  14. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Wao! I like your passion. Four Prii for a learn?
    Are the prii same model years or ? I'd ha e bought only one or two, then use the remaining cash for other things like investing on tools.
  15. marilyn Stone
    marilyn Stone New Member
    they replaced the fuel sending unit on my car when that code was pulled. cost me $600 but seems ok now
    SFO likes this.
  16. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Thanks for replying Marilyn!
  17. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Which code (DTC), and what ended up being the solution?
  18. RideCustom
    RideCustom Junior Member
    san bernardino
    I just have the same exact problem. 2005 gen2 that i was trying to figure out for a friend. p0a0f and p3190. Engine started for 5sec and then shuts off. Hybrid battery on 1 bar. I think it was because the hybrid battery is not getting charged back from the engine. Spent 12hrs trying to figure out the issue. Took out the hybrid battery and rebuilt it, same problem. So that’s not it. Check fuel pressure, good pressure and there’s gas in it. Check spark plugs and coil, they are good, not misfiring codes or counts. Oil is definitely not over filled. So i ran out of anything i could think of…UNTIL :cautious::cautious::cautious:…I checked out the engine air filter, which i thought it looks kinda odd and dirty. I asked my friend when the last time he changed his air filter. He said 2 months ago at an auto shop near his house. I was like Huh!!?? should be this dirty unless he drive this thing in Afghanistan thru a mummy desert storm or something! So i bought a brand new filter to replace it and that’s when i notice the MAF and throttle body are awfully dirtier than usual. While changing out the air filter, i finally figure it out.! The shop that changed his air filter they put the air filter in the wrong direction! and not only that, the filter doesnt fit quite right, so they poke 2 holes in the rubber part so it would fit under the retainer clip thing! it has been causing all these dust and dirt and pine needles to go into the throttle body and clogged up the MAF! once i replaced the filter and clean the MAF and throttle body up real good, the car starts right up perfectly and stays running. I could not believe I did not check the air filter first…to be honest I would not have expected that someone would have screwed up something such simple like this. Problem solved. But now he has to go talk to the shop owner to see who was that idiot that put the air filter in the wrong way!
  19. ChapmanF
    18,717
    Another keeper for the "Why I DIY" collection.
  20. mr_guy_mann
    mr_guy_mann Senior Member
    4,101
    2,003
    NJ-USA
    And in the meantime, the engine ingested a whole bunch of dust and dirt.
