P0a40 & P0a41 codes after engine replacement.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RajivR74, Jun 9, 2019.
  1. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    I have been working on a 2013 Prius for a friend who's an Uber/Lyft driver. It's his sole source of income & it has almost 370,000 miles. That's right 370k miles! The engine was replaced by someone else (500+ miles away) & the car made its way back home just fine but after 2 days of rideshare driving, it threw itself into limp mode TWICE on the expressway. The codes P0a93 & P0a94 lead me to check the inverter coolant pump which wasn't running so I replaced that & then the inverter which got rid of the P0a94. But now I have codes P0a40 & P0a41 (drive motor codes) that pop up as soon as the car goes into limp mode.
    I have a Bluetooth obdII reader plugged into the car and I am able to clear the codes & continue driving normally until the car goes into limp mode again & throws codes P0a40 & P0a41 again. I can trigger the limp mode & codes at will by taking my foot off the accelerator pedal abruptly.
    I'm hoping it's some sort of loose connection that happened during the engine replacement. Where should I start looking? I'm hoping that I can fix this car for my friend. He has already spent over $2000 on the engine replacement & this car is his only source of income. I am quite familiar with the second generation Prius but not the third. Please help! Thank you!
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Pluggo, Skibob, bisco and 1 other person like this.
  3. RajivR74
    37
    Horn Lake, MS
