P0A4B workup... >1V on HV control ECU M5 connector
Discussion in 'Gen 2 Prius Main Forum' started by jeremybub, Apr 14, 2026.
  1. jeremybub
    jeremybub Junior Member
    Vermont
    Here's the background (may not all be relevant)
    1. When out of state my 2009 Gen 2 Prius with 235k miles threw up the red triangle of doom. I took it to a shop, and they reported "TRIANGLE OF DOOM...p1121 water valve code...p0a4b transmission connectors...remove and replace water valve and bleed coolant in inverter"
    2. The next day the check engine light came on, and a couple days later the red triangle came back. I was at home so I was able to scan with techstream, and got P0A4B, P0420, C1242, C1310.
    Of these codes, P0420 (Catalytic converter) seemed independent, C1310 (Malfunction in HV system) seemed secondary, and C1242 (Open in IG1/IG2 power source circuit) seemed possibly secondary , leaving P0A4B (Generator Position Sensor Circuit) as my likely culprit. (the P0420 and C1242 were also intermittent when I restarted the car).
    3. After resetting the codes, none came back (only driven briefly a couple times though).
    So I am focusing on diagnosing the P0A4B, using the workup from this thread: https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a4b253.pdf
    So basically I am checking the connection from the HV control ECU to the MG1 Generator Resolver port. Following their directions
    1. I check the pins in port on the ECU, measuring voltage to ground, with the car turned on. All 6 measured pins were >1 v, either 2 or 4 something volts, except the CRFG pin.
    2. I don't have long enough cables to check the resistance of the connector from one end to the other, so I didn't check that
    3. I checked for shorts from the connector to ground as specified, and did not find any.
    4. I checked the resistances of the Generator Resolver port as specified, and everything was in spec.
    5. Just for fun I checked for shorts between the different pins on the connector, and found nothing.
    I also checked for corrosion or damage to the cables or ports but everything looked very nice and clean. I cleaned both sides of the connection on the generator resolver with brake cleaner just for good luck.
    Any help interpreting the voltages on the ECU pins? According to the workup, if the voltages are above 1v, you are just supposed to "REPAIR OR REPLACE HARNESS OR CONNECTOR". But this seems odd to me... it's not like they have crazy voltages, and the car isn't even giving a code any more... Does it really mean the whole ECU is cooked?
  2. pasadena_commut
    pasadena_commut Senior Member
    3,045
    946
    Southern California
    Did this happen at start up or after it was running for a while? If the 12V battery is EOL it can let the gremlins in, and that shows up when the car first turns on, or at least, tries to.
  3. jeremybub
    Vermont
    The red triangle both times began at startup. The check engine light though started after driving for a bit (and also disappeared while driving).
    The 12v battery had previously died a few months ago in the Vermont winter, and I had to trickle charge it back to life, but it hasn't had any issues since then.
    That does seem plausible as contributing, but I still can't make sense of the diagnosis of >1V pins on the ECU, and I'm not sure how the battery could be causing that symptom, while at the same time throwing no codes and generating no other symptoms.
  4. PriusCamper
    PriusCamper Senior Member
    13,450
    5,430
    Pacific Northwest, USA
    P1121 creates a check engine light, but not a Red triangle. Most Gen2 heading toward end of their second decade will start to have a failing sensor in the 3-way valve in coolant system so they found P1121 and fixed it, but never dealt with your unique gremlins.
    A strong healthy 12 volt is essential... And same goes for your high voltage battery, as they both have the ability to create gremlins if they're old and have never been given much attention. And hopefully error codes don't come back and you're good. But if they do come back hopefully its just one error code.
    I've no recollection of discussions on Priuschat about these particular sensors being a problem, so your symptoms are rare. Also Gen2 transmissions are exceptionally reliable due to their simplicity.
    Suspect if you aren't done with this problem and red triangle comes back you're going to find a fix if you keep doing lots of cleaning and inspecting of electrical components in the hybrid system / regen brake system to see if you can find a weak, loose, or corroded connection that needs some work.
    If that doesn't solve it, find someone with a similar Prius and borrow their ECUs to see if you can diagnose it that way.
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Bear in mind that the link is an excerpt from a 2004 repair manual. Your car is a 2009–there have been changes made along the way and significant changes at the 2006 refresh (Gen 2 v2, if you like). It would pay to be working from a 2009 repair manual. In this instance, there may be no difference in the workup, but it would be a bear if there were differences. Better still, would be to work from the online document that is on TIS, which would be the most up-to-date, with errors found since 2009 corrected.
  6. jeremybub
    Vermont
    Thanks for the suggestion, I did have a 2006 version of the repair manual as well, and there is an additional section to check for shorts between *all* of the pins on the Generator Resolver port, which I didn't think to do. If anyone knows where you can download a newer version I would be happy to hear about it. (I don't have a TIS subscription)
    I replaced the hybrid battery last year (with a used one), and the 12v twice in the past two years (with new ones). I hope I don't need to do it again...
    #6 jeremybub, Apr 15, 2026
  7. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    So with the 12V correct and all that . Do you still have the resolver issue the code now ??? look at John's videos Prius univ . And you can see these parts they monitor positions of the mg1 and mg 2 positions . Seen some foreign texts of guys basically the opening up trans or swapping . With long test leads I have 12 footers . They can rule out ECU and cabeling pretty fast. But you cannot get past those resolver covers for wiring to get at the part/s. Trans is coming out . Too many around to troubleshoot and buy real parts for . Rare issue only read about a very few times . The odds of getting a tans w same . Would be out they're for sure . But some might have that luck
    PriusCamper likes this.
  8. ChapmanF
    19,008
    The resolvers are critical parts, but they are also inside the transmission, where it's next to impossible for anything to happen to them. It would also be deep transmission teardown to replace them, and the procedure to calibrate new ones is factory-only, with no published information for doing it in the field.
    Happily, pretty much any time a resolver code comes up around here, it ends up down to some damage to the wire harness near where it plugs into the transmission, thanks to either a collision or some sharp-toothed critter.
  9. jeremybub
    Vermont
    Drove it ~50 miles today, no codes of any sort showing up. Hopefully it was just fixed by cleaning and re-seating the connector? I still am curious about whether anyone understands the >1V test, and what it means that my car has voltage on those pins...
  10. PriusCamper
    13,450
    5,430
    Congrats... Hope it lasts... Cleaning and inspecting is my favorite way to fix a broke down car! It's like nothing was wrong other than the car needing a little love! :)
