P0A7F...found the green crusties!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tbkilb01, Jan 5, 2018.
  1. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Don't have to pull it to check for needed cleaning...easy on 3rd gen, pull hv plug then unscrew cover...
    If need to pull to service, it's just a few more nuts and bolts...
    Raytheeagle, leeb18c, scona and 2 others like this.
  2. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Thanks. I'll check mine out when I have a chance.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    May as well install a Prolong harness if you are diving in:).
    Now that the head gasket is fixed and you’ve got the catch can, the last thing is the battery;).
    Sure you need the Volt anymore :whistle:?
    SFO likes this.
  4. Tbkilb01
    218
    187
    Louisiana
    Well I check codes and found dreaded history code P0A80
    Had hybridAutomotive ship out the load tester and I found quite a few modules dropping excessively under the light bulb load. I ended up just replacing the worst 14 modules. I Had hybridAutomotive ship out the charger/balancer and discharger set. Did the 3 day charge/discharge adventure again. Afterwards I Went out on road to complete three drive cycles and low and behold the code is no longer in history. I went a head and ordered 6 more just for fun and giggles. I really want to thank HybridAutomotive for their professionalism, quick ship, and communication! Now I need to figure if any of my modules can be charged back into good use?
    #24 Tbkilb01, Mar 17, 2018
    RMB, Mendel Leisk and Raytheeagle like this.
