P0A80 advice...
Discussion in 'Gen 3 Prius Technical Discussion' started by Paul E. Highway, Oct 5, 2021.
  1. Hi_prius3
    Hi_prius3 Junior Member
    46
    Honolulu,HI
    Bummer about your P0A80 code, but I’m not sure what you need to do to fix it. You probably have another bad module or possibly just the difference in resistance is triggering the code. I hope you can figure it out.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Are you monitoring block voltages while you drive? You should see a high "Voltage Diff" value at some point along with what ever block voltage is going too far above or below the others. Likely happening at high loads- heavy accel or braking/regen. I believe DrPrius will datalog on android then you can view the data in MS Office. If you have Techstream you can see if there is freezeframe capture for the P0A80 with any additional info.
  3. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
    I had Battery Monitor screen (Dr Prius) on during all the test driving and the voltage difference was between 0.05 and 0.10. Before putting in the 5 new modules I’d seen as high as 0.40 when it threw the P0A80 code.
    I only have iOS so no datalog.
  4. Hi_prius3
    46
    Honolulu,HI
    My voltage difference range according to Dr. Prius app was 0.10 to 0.51v and a 1 milli-ohm difference in the resistance on just a single block. It may be the resistance and not the voltage difference causing your code still.
    I read somewhere that you can replenish the electrolytes to restore the resistance and battery block to acceptable level. I’m just not sure if it’s worth it until you figure out what is triggering your P0A80 code.
  5. Paul E. Highway
    210
    131
    Hawaii
    Not sure how to attack the resistance thing. Or even how to measure properly. Dr Prius just says “19” for all blocks, and Car Scanner Pro says “0.02”. Wonder if I need a really good multimeter for this?
    Took car out this evening, threw codes at 0.13 and 0.14 voltage differential. Doesn’t seem like enough to cause a code. Then it threw a code with block 14 at 13.72 volts (1.61 volt diff) and 6 minutes later block 14 had the highest voltage at 17.26!
    Gonna sleep on it!
    4DCAC3D6-4C62-465C-A12F-A55089C83DDD.png 7055821D-5C98-49B9-8B10-6A237EDE7E37.jpeg 48B9CFDF-D6BD-4618-920C-0368A5A87E08.jpeg
  6. Hi_prius3
    46
    Honolulu,HI
    I think you need to use Techstream. The Dr Prius app did not reveal a few blocks that Toyota said were also weak. That’s why I took my car into Servco. Your resistance looks good so you probably just have another bad block or two under load and a voltage difference. Finding which one is the hard part. I think your #14 module needs to have a more similar spec’d batteries paired together because the difference is too big. But, I’m not sure what the parameters are that actually triggers the P0A80 code, so I’m just guessing.
    Sleep well!
    Paul E. Highway likes this.
  7. Paul E. Highway
    210
    131
    Hawaii
    I might load test all the modules again so I have a better idea of what is going on. Getting pretty good at it. And that’s why I didn’t put the floor and cubby box bank in yet, so I could still tinker…
  8. Hi_prius3
    46
    Honolulu,HI
    That’s a good place to start. You may have to leave out the floor and box a little longer. Hopefully you’ll get it sorted out soon.
  9. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Sorry bypassing the hardness wastn't your problem.
    But it sounds like all the packs are failing. You may eventually be able to match enough of them
    to get it working, but for how long?
    The stronger batteries will only put more stress on the weaker ones which will cause them to fail.
    But, I do hope you are able to sort it out.
  10. MrPete
    MrPete Active Member
    508
    194
    Colorado, USA
    Hiya... I am going through the same. Not done yet.
    A few hints:
    * In Dr Prius, resetting codes ALSO clears any knowledge of IR (Internal Resistance.) Save IR before clearing!
    * A better app for tracking block voltages during charge/discharge/driving is Hybrid Assistant. Creates wonderful graphs of all blocks. And can export the data.
    * So far, I have learned that an extra-good or extra-bad block can throw a code during extreme drain. HA app will show the spike in delta-V (ie a block briefly drops its voltage WAY down, while other block(s) stay high.
    More later. Will post my stuff on my thread...
  11. Paul E. Highway
    210
    131
    Hawaii
    Aloha!
    I can't use Hybrid Assistant because I don't have any Android gear. Car Scanner app for iOs lets you create dashboards for just about every sensor on the car. But interpreting that data is another thing.
    Here is the load test data on my modules from yesterday, comments appreciated. The 5 highlighted modules are the replacements for the 5 worst modules I had. I moved outside modules to the middle and vice versa, and tried to pair modules with similiar in terms of load performance. Then did the full Prolong process over 5 days, and still getting the P0A80 code and triangle of death.
    If a couple modules might fix, I might try, otherwise leaning towards a new battery. (Modules 8, 13, 14 are all greater that 0.050 v in the load test, would replacing those 3 make a difference?)
    Thanks for looking!
    PEH
  12. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    i wonder if switching module 8 and module 13 would help. It looks like youre so close with everything, hopefully you can make this pack work for longer. Do you have a way to measure the mah of each module and match according to the capacities? These are just ideas and I have never actually reconditioned a battery yet, so far just a reader
  13. MrPete
    508
    194
    Colorado, USA
    My thoughts:
    * Not sure how you matched up modules. Given the data you provided, see my new arrangement (attached)
    - I sorted on vAfter
    - Then made blocks (a-n) of lowest+highest
    - As you can see, again assuming your data (see below for more on that), I have improved vDelta from (.09-.31 volts) to (.05-.11 volts) -- almost 300% improvement in "worst case" vDelta...
    The Harder Issue, IMHO (just an educated guess as a EE... I do NOT really know what I am talking about at this point!!)
    - measuring only after the modules have a chance to "recover" rather than at peak load...
    - means we are not really matching module performances to make truly "similar" blocks.
    - AFAIK, what drives the ECU nuts is when vDelta skyrockets during an extreme battery drain. I will try to upload a graph from one of my runs.
  14. Paul E. Highway
    210
    131
    Hawaii
    Thanks for the new arrangement! Can't hurt to try.
    Just so I understand, modules 1 and 7 ( the "a's") make up one block, and so on?
    Cheers
    PEH
  15. Paul E. Highway
    210
    131
    Hawaii
    Aloha!
    Had time to pull the battery today and move the modules around per Mr Pete’s suggestion. Took the car out tonight for about 40 mins, did 30 mph in town, ECO and PWR, AC on and off, then ran up and down a couple hills. NO ERROR CODES! Cautiously optimistic.
    I have the Prolong gear and in last couple months did a recondition after replacing dirty bus bars, and again after putting in 5 modules to replace worn out ones. Should I be charging or discharging again at this point?
    Options:
    A) Full recondition
    B) Charge only
    C) Discharge (to what voltage?) then charge
    D) Do nothing
    Here’s some screen shots from drive tonight:
    842E207B-5662-40AD-9E89-1252439351A7.jpeg 3EF31A15-A462-4B00-926C-013905CA7D51.jpeg 97BC0C17-BB1F-44DE-9E25-2AFDE5FC43E6.jpeg
    Thanks for everyone’s help so far!
  16. MrPete
    508
    194
    Colorado, USA
    That's a great result!
    And yes, a+a are intended to be a block, etc.
    I was NOT specifying the block sequence. It was just low-to-high. As most suggest, you want the best blocks in the middle, where it gets hottest.
  17. Paul E. Highway
    210
    131
    Hawaii
    I’ve gotten a few error codes here and there but it’s seems the more I drive normally (less cruise control, less gliding) the less codes I get. Confident enough now that I put the rear seat and floor back in. Still think the battery is old and tired but if I bought some extra time that’s great.
  18. Paul E. Highway
    210
    131
    Hawaii
    Still getting a couple triangles of death a day so ordered a Newpriusbatteries setup and will have it next Thursday. Stay tuned!
    ASRDogman and nancytheprius like this.
  19. Hi_prius3
    46
    Honolulu,HI
    I’m saddened to hear that. I may have to do the same. Please keep us updated on your progress.
    Thanks
  20. nancytheprius
    365
    157
    iowa
    That will give you peace of mind for the next few years!
