P0A80 but all voltages look normal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by k1ngn0thing, Mar 15, 2018.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    all my cell voltages are right around 17 but I'm getting P0A80, and my HV drains within a minute of sitting idle. these values are after the car has been sitting cold, simply starting it up without driving.
    #1 k1ngn0thing, Mar 15, 2018
  2. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    showing rapid cycle
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Your safety disconnect is probably not installed correctly. The only time I've ever seen the MFD SOC display act like that was when a safety disconnect was installed but not fully interlocked. (that last push downward to actually seat the electrical connectors for the interlock)
    #3 TMR-JWAP, Mar 15, 2018
  4. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Re-reading your post...when you initially press the power button to start the car, does the engine ever start to perform a warm up cycle? Have you ever done any work to the HV battery?
    You definitely have an unusual problem. All your individual indications are that the HV battery could be fine, but the SOC display on the MFD makes no sense. Just thinking out loud but I wonder if theres a connector issue in the HV battery electronics or an ECU problem.
    #4 TMR-JWAP, Mar 15, 2018
  5. bisco
    52,773
    are you testing them under load?
  6. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    is this a warmup cycle?
  7. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    no load, should I be?
  8. bisco
    52,773
  9. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    what should I be looking for while under load?
    also here's a readout with it running:
    should I use AC or heat as load?
  10. bisco
    52,773
    the delta between modules.
  11. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    Delta SOC holds steady at 1%. here's a recording of everything while under load. first AC, then heat.
  12. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    it appears block 7 is the issue as it's a little low compared to the rest, so hopefully I can fix it with the prolong charging/discharging kit.
    Raytheeagle and bisco like this.
  13. bisco
    52,773
    contact jeff for advice.
    Raytheeagle likes this.
  14. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Block 7 most likely is causing the P0A80. You might be able to rejuvenate the weaker of the two modules in that block with the Prolong system which will save you a lot of work otherwise. Hope you are successful with the Prolong.
    k1ngn0thing likes this.
  15. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Soooooo.....we're saying that at idle, with the voltage only fluctuating a few tenths of a volt, that a bad module in block 7 is causing the MFD SOC indication to fluctuate from full green bars to no bars? But no P3017 code?
    I'm not saying block 7 is not an issue. All I'm saying is that I've seen a couple batteries with failed modules and I haven't seen that MFD variation.
  16. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    could be my cheap chinese OBD isn't picking it up, however I don't recall there being any other when I had auto zone scan it, unless theirs didn't pick it up either.
  17. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    Seeing as no-one actually answered this question, and recognising it is a bit late, but better late than never, what you are looking for, are modules that discharge faster under load than its peers and (usually) the same modules charge faster under charge than its peers. These are the best signs of modules that are out of step and render the battery towards failure.
    If you replace these modules, as a cheap quick (but short-term fix), you will still need a method to charge and discharge each module. You can do this using a (or several) RC charger(s) on individual modules (cheap, but more time consuming, effort and inconvenience) or you can charge the HV battery as a whole using a grid charger/discharger (more expensive, quicker, more convenient). Many here use the HA Prolong system to do this.
    Looking back at you screenshots, your IR values all show 0 (as well as IR14 missing, will need to manually add to PIDs), which is incorrect and I suspect there is an error in each formula in the PID. @ericbecky uses that software and I know he is happy to take calls, so a call to him can probably sort you out. I mention this as IR is a reasonable indicator of the state of health of each module. New modules usually start in the 0.018-0.019 Ω range, but as they become more used they get above 0.030 Ω.
    Hope you find some of that useful.
  18. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    Was able to see the resistance values in the dropdown. Lucky number 7 is proportionately higher. Definitely the culprit. Will update after the Prolong process. I don't know Jeff's username, but if someone could tag him I'd like to ask him how many cycles he recommends for this situation.
  19. dolj
    dolj Senior Member
    8,633
    4,386
    It's @jeff652, and he's just been tagged.
  20. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    The 0.0 IR should just be the result of the resolution selected. Typical values would be like a 0.025, so it rounds to 0.0
    The display can be adjusted to show the actual value.
