P0A80, C1310, P3018, C1300, and C1259 Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bonzi, Jan 18, 2016.
  1. Bonzi
    Bonzi New Member
    Colorado
    My car set out in the cold snowed in for a month. Unfortunately the dome light was on. Battery was dead. I jumped started it and drove it and the next time I started it all these codes popped up. It has 144K miles on it but was running fine before. Is it possible I screwed something up jump starting it or there is a problem with the 12V battery? Or is it the dreaded battery pack replacement? Engine stays on even at a stop, battery fan is blowing, and the battery indicator is usually full green..then goes down...then back up to full green. Any help is appreciated.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I would start by checking and probably replacing the 12 volt, sounds like you need it for sure, then clear the codes and see what pops up (I hope nothing, but at 144k.........)
    52,816
    welcome! agreed ^^^ sometimes the 12v can cause codes. replace it and cross your fingers.
  4. Bonzi
    Bonzi New Member
    Colorado
    Sucks...I was getting over 50 MPG..better than when it was new. I have only replaced the 12V once in the past 10 years. Its never even been to the dealership except for the HID light replacements that where under recall. It has a ton of hail damage so I could probably total it out but not sure now since it has all the warning lights on.
  5. bisco
    52,816
    you might try charging her up and see how she holds.
  6. Bonzi
    Bonzi New Member
    Colorado
    It starts right up...but the gas motor does not turn off at a stop. Really slow to get going because the electric motor is not assisting. Getting 40 MPG instead of 50 MPG. I wonder if it will keep running without the electric assist.
  7. bisco
    52,816
    it will run as long as the battery has the power to start the engine. but when it doesn't, you'll be stranded.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    1 time in 10 years?
    Time to do it again.
    Start there and report back.
  9. Bonzi
    Bonzi New Member
    Colorado
    Will do. It was not terribly bad to replace. And this problem started with the dead battery. Crossing my fingers this is the root of the problem. Its been such a great car. Ordered this on Amazon...fingers crossed. Optima Batteries 8171-767
    #9 Bonzi, Jan 18, 2016
  10. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    you need a bluetooth odb2 scanner. then you'll be able to read/reset the codes and monitor the car closely.
  11. Bonzi
    Bonzi New Member
    Colorado
    I got the new 12V in the mail today...but thinking I shouldnt use it and send back. The fan for the hybrid battery is running and getting no electric motor assist. But it does seem like the electric motor is running...I can hear it when I turn off the engine. 12v volts starts right up so it is getting a charge. Not sure what to do. Doesnt turn off at a stop and gas motor turns on right away unlike before. Any suggestions?
  12. bisco
    52,816
    why not test the battery?
  13. Bonzi
    Bonzi New Member
    Colorado
    The hybrid battery or the 12V?
  14. bisco
    52,816
  15. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Sorry. Any battery more than a few months old that sits in the snow for a month with the dome light on is done.
    Regardless of whatever else may be wrong with your car, the 12V is shot.
    Next, get a minivci.
