P0A80 Code, checked battery, all cells fine, cleaned busbars, light still on!
Discussion in 'Gen 3 Prius Technical Discussion' started by dirt657, Dec 21, 2018.
  1. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Checked all the cells, all read the exact same, perfectly fine, cleaned all the busbars, cleaned fan, through it all back together and light came back on. Any idea?
    amos likes this.
  2. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Also, this light came on the first time after cleaning the intake manifold. Is there anything that I possibly good have unplugged down there that would’ve thrown a light?
    amos likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Anything is possible but the reason that the code displayed will be available through Techstream ;).
    Find out what is causing the code to set and it’ll be better than throwing parts or time at reasons that the code didn’t display. This method works until you get to the last thing you try as that will be the reason it doesn’t have the code anymore.
    But that can take awhile and cost a small fortune:cool:.
    Do you have Techstream or a way to perform further diagnosis?
    Good luck and keep us posted (y).
    #3 Raytheeagle, Dec 21, 2018
    amos and jerrymildred like this.
  4. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I do not use tech stream. I’m assuming you download on your laptop and then use a K-Dcan cable? How would I use tech stream for that?
    amos likes this.
  5. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Send me a download link if you wouldn’t mind.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I bought a J2534 protocol dongle off of Amazon for ~$20 a couple of years back and have Techstream version 10.30.029 paired to a 20 year old windows cap laptop. It’s te most powerful and useful diagnostic tool for your troubleshooting tool box.
    You need a way to have Techstream read your Prius and this is the cheapest way. A bit more pricey is VX DIAG but this is less buggy and streams the data better.
    Your best option is to find either another member here or a shop that can give you the reason the main battery code is being thrown.
    amos and RMB like this.
  7. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I noticed that the battery drains while sitting there....what could that be?
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    You’ll have to give us some more details like:
    • Sitting there in “ready”?
    • Where do the bars start out at and how fast do they drain?
    • What accessories do you have on during this observation?
    • Does the Prius charge the battery back up?
    • What happens when you force charge it?
    • Will the AC system run if you tried turning that on?
    amos likes this.
  9. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Ready stays on
    The bars look normal as a matter of fact the code just came on again on the freeway
    No accessories on
    Battery charges up fine
    I’m not sure how you force charge it
    Ac System works great
    amos likes this.
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    What do the bars do that you consider normal.
    The more detail the better to help understand what the root cause may be.
  11. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    As far as checking the cells, isn't there a trick of putting them under load to actually find the bad cells? I'm just thinking about other threads discussing this same problem. Where owners were getting normal readings off the the individual units with no load on them, once there was a tiny load on the individual cells the bad ones show up quickly.
    Raytheeagle likes this.
  12. Absalom
    Absalom Junior Member
    42
    42
    Denver
    I have the same issue as OP. I have access to Techstream, is there a flowchart I can run through to diagnose?
  13. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    How do I do a load test?
  14. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    You didn’t mention about torque values on the buss bars.
    amos and Raytheeagle like this.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Will you be able to monitor the battery when you put it under load?
    One way to do this is to stress the battery by placing everything at max like the ac system then try to run up an incline.
    amos likes this.
  16. Absalom
    42
    42
    Denver
    Any thoughts from others?
