P0A80 code checked battery voltages and show good, now what
Discussion in 'Gen 3 Prius Technical Discussion' started by Alan2010gen3, Nov 8, 2017.
  1. Alan2010gen3
    Alan2010gen3 New Member
    Indiana
    Hello all,
    My first thread and Prius.
    I just purchased a 2010 Prius with 230K miles. Drove it home even though it had a P0A80 code.
    I purchase it from the original owner and planned on "fixing" the battery.
    I replaced 3 cells in a friends Gen II and it has worked great every since.
    When testing my friends Gen II cells, 3 stuck out with at least 0.5 less volts than the others.
    I pulled this Gen III pack out and all the cells were withing .06 volts (7.95-8.01).
    There was some corrosion on the bus bars, but all contacting areas in including the sensor connectors appeared good.
    The fan and ducting was ok.
    After helping my friend, I figured this an easy fix........................................................
    What would you suggest for the next step?
    Thank you in advance for your help and time!
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Some ideas:
    - With battery properly mounted in the car, watch the voltage data live with an app or Techstream to see what is happening under load.
    - Record the data and analyze it for anomalies.
    - Look at other info like delta SOC to see if there are other issues at play.
    - Take the battery out and inspect it on the bench.
    - Look very carefully every voltage sensing wire. Probing them vigorously at the crimp connections.
    - Check for corrosion at the connector that goes into the hybrid battery computer, including the pins of the computer itself.
    - Check the terminals to be sure they are properly torqued.
    - Load test individual cells and see if there is variance.
    Raytheeagle likes this.
