1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears..
    I need your help to solve this fault code ..or to know the reason behind it..
    I have cleaned the hybrid battery fan because i thought this was the reason but no..still the alarm came..
  2. isano.chan
    isano.chan Junior Member
    Indonesia
    It's time to replace HV battery. Year and mileage?
    SM-N9208 ?
  3. Tariq87
    Tariq87 Member
    87
    28
    jordan
    No SM-N9208 just P0A80
    It's 2012 with 150000 kilometres
    So it's a must to change the HV battery?!
  4. isano.chan
    Indonesia
    2012 supposedly too early to replace hv battery.
    SM-N9208 ?
  5. Tariq87
    Tariq87 Member
    87
    28
    jordan
    What do you mean by
    SM-N9208?
    i thought it's an error code
  6. Prodigyplace
    12,710
    11,848
    Central Virginia
    Some mobile apps try to guess the phone device and add it as a signature.
  7. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Yes i got it thanks
  8. bisco
    52,785
    it's not the year, it's the km's. while not excessive, in warmer climates, it's not out of the question. it sometimes depends nowhere it is parked all day.
    you can get a second opinion. are there any symptoms besides the dash lights and codes?
    it might be worth checking the 12v health, just to be sure it isn't causing a false code.
    if it turns out to be a bad hybrid battery, there are repair options, but they are complicated, and don't hold up like a new battery.
  9. Tariq87
    Tariq87 Member
    87
    28
    jordan
    The hybrid battery blocks gives me reads between 16.1v and 16.24v which is good.. but why this fault code came??!!!
  10. bisco
    52,785
    are you testing them while driving? you must put a load on them to get a correct differential.
