P0A90, P0A94?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SkipRaff, Mar 1, 2025.
  1. SkipRaff
    SkipRaff New Member
    Connecticut
    Long explanation to my question. This afternoon I was making 160mile round trip drive. About half way back 40-45 miles I went to stop to grab a coffee. Up until then everything was perfect. Put on the directional and slowed to turn in to the parking lot and suddenly “check hybrid system “ came up and the car lost all power and I rolled to a parking spot. I shut it down and took a minute , then restarted and went for it to see if it would drive or I was dead in the water. I was lucky (I guess) and it drove. Check hybrid still on as well as triangle ! Light, quote ! Light , traction light, and check engine light. The car accelerated like it was a manual transmission with a bad clutch and also stuck in 1st. But slowly climbed up to speed. It always felt light it was reved up about but the mpg fluctuated like normal 100mpg down to 20 based on my acceleration. I was able to drive the remaining 45 miles home at 70 mph highway speeds and consistent back road speed…with the exception of the slip clutch feel and the higher rpm’s it ran without a problem to get home luckily.
    When I got home I ran the codes. POS90, P0A94, both control unit 7EA. Also codes C1259 and C1310.
    I looked them up and it vaguely points to an inverter but also other things including low or bad 12v battery.
    Added: I alway manually shut off my head lights even though I see they will shut down on their own. But today I forgot. could that have worn down an old possibly weak 12v battery enough to after 40 miles set my chain of events? Also, I’ll add, a few minutes prior to this I turned on my heat also. Wondering if the heater fan load on the battery triggered a drop in a battery on the edge of low volts to drop enough to trigger my coated and events.
    I’m hoping someone has some insights and explanations to rule out my thoughts or validate. Tomorrow I’ll test the voltage, but for now looking for some info and prying it’s just an old battery issue. I’ll also note: my daily commute is one mile each way with headlights in the am. I’ll go months without driving more then the commute and or a few miles around town. I’m wondering if I’m killing the 12v by not giving enough driving time to maintain voltage.
    thank you for any help and insights.
    2010 model.
  2. SkipRaff
    SkipRaff New Member
    Connecticut
    I just ran scan tool. Foxwell. I snapped a few pictures of what the batteries were doing( I guessing that’s what he graph represent) the first is just starting the scan and the car on but not running. The dip in voltage is where I turn on the headlights. I’m not sure on the charge percentage for the hybrid bat, I’m not sure how that works…if it goes up or down based on charge. And finally the volts (2nd pic). The other pic is with the engine running and the 12v jumps to the 14.8 but the charge percentage begins to drop. I went for a quick drive and all the drive problems from my post are still there. The hybrid charge percentage did go , and stay , around 40%.
    I’m curious and hoping the now voltage and with the load lower it more indicates the 22v battery is causing the problem (HOPING) but it seems odd that when running I was getting the 14.8v …or is that because it’s drawing back from the hybrid battery ( I thought I read that somewhere)
    Again. I appreciate any help, thoughts. I can not get sub codes only the PO’s.
  3. SkipRaff
    SkipRaff New Member
    Connecticut
    I just did these next three screenshots. The one that shows 11.9v with a drop is with car on but not running and I turned on the lights. the jump to 14.8 is when I turned on the engine. And the steady(sort of) 14.8v is as it’s running. I noticed a slight drop in the hybrid battery when the engine was running and the 12v was reading its 14.8v.
    Any ideas?
  4. SkipRaff
    SkipRaff New Member
    Connecticut
    Sorry. Last part I need to add. On the drive and at idle it never switched to electric. Usually if I’m sitting at a light or whatnot it will switch to electric only. Also, other then all the warning lights and continuous engine running it seems normal EXCEPT the slipping at acceleration.
  5. ChapmanF
    19,041
    C1259 and C1310, as you can read here, are just codes set by the brake/skid ECU when it has received news of codes in the power management control ECU. Those, of course, are your P0A90 and P0A94 codes.
    Given that the P0A94 code should qualify you for coverage under Customer Confidence Program 23TE03 as you can read about here, I would suggest contacting a dealer promptly (without clearing the codes) so they can sort it out.
    Brian1954 likes this.
  6. SkipRaff
    SkipRaff New Member
    Connecticut
    Wow, thank you! I’ll give my dealer a call tomorrow. I bought my Prius used 2 years ago from a Toyota dealer , so I definitely be inquiring to them. I appreciate your help.
    So, would the P0A94 fall under a warranty coverage?
  7. Brian1954
    Brian1954 Senior Member
    2,693
    1,076
    South Central PA, USA
    Yes, it is covered under a 20-year extended warranty. The repair will be covered 100% by Toyota, so make sure you do not clear the trouble code.
    SkipRaff likes this.
  8. SkipRaff
    SkipRaff New Member
    Connecticut
    Cham
    thank you for this. I bought my 2010 from a dealer 2 years ago. I will reach out to them tomorrow…Also, closer to me is the actual dealer that sold the car when it was new. They are in my town. I saved the bulletin and have not cleared the codes. thank you again.
    edit: sorry about the repeat reply. I didn’t see my first had posted. I wanted to be sure you got my thanks for the info. Very appreciated!
    #8 SkipRaff, Mar 2, 2025
  9. SkipRaff
    SkipRaff New Member
    Connecticut
    Update:
    I stopped in at my local dealer today after work they looked up my vin and said indeed there is a warranty for the P0A94 and it looks like I qualify. I’m dropping the car there Thursday morning for the diagnostic. If everything fits criteria, it’s all free including a loner car while they get the parts and do the work. I will update when I get the info from the dealer Thursday.
    Thanks again ChapmanF for this info!!!
  10. SkipRaff
    SkipRaff New Member
    Connecticut
    I got the call from the dealer this am. Totally covered under the warranty!
    Thank you so much ChapmanF fit the heads up on that. I can not express how grateful I am!!!
  11. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    So are they completely replacing your inverter? I Was thinking more of it being the bad 12v battery, a bad battery can cause all sorts of issues to pop up.
  12. ChapmanF
    19,041
    It depends on how much of the magic smoke escaped. There are several internal components they may end up replacing one or more of, based on what the repair instructions tell them to check. They aren't told to replace the whole unit unless the failure blew a hole in the case.
  13. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    That's great, keep us updated - I'd love to hear how it all comes out.
  14. SkipRaff
    SkipRaff New Member
    Connecticut
    Update!!! I got my car back last Monday…very busy life/work week and did not get a chance to post this update. Toyota fixed the problem under warranty, zero cost. They also picked up the rental car cost for the week plus that they had my car and had to order the parts. Had to do a 150 mile round trip drive today…same drive where the problem happened. All good and averaged around 45mpg for the trip. I was more than happy with the treatment by our local Toyota dealership…even before it was confirmed that warranty would cover it…and especially after it was covered. And that they went , to me , above and beyond to supply an Enterprise rental , Hyundai Kona hybrid (have to admit, it was a nice car) when they did not have any dealership liners available.
    I want to once again thank ChapmanF!!!! I was really in a tight spot before he replied and literally saved the day for me. Thank you! I very much appreciate you for turning me on to the warranty.
  15. ChapmanF
    19,041
