P0A93 code, car is dead
Discussion in 'Gen 2 Prius Technical Discussion' started by eminar17, Aug 8, 2020.
  1. eminar17
    eminar17 Junior Member
    Olivehurst, CA
    A couple hours ago, I was driving home and the red triangle and check engine light came on. I was able to get the code checked and one code came up: P0A93. It was running fine so I thought I’d be okay to drive a few minutes to get dinner. On the way home, the car died completely and will not turn on at all. There is a burning smell too but no smoke. What could it be?
    52,876
    p0a93 sounds familiar, let me google
    52,876
    found it, you need a new inverter pump
    edthefox5 likes this.
  4. ttou68
    ttou68 Active Member
    351
    211
    Inverter pump may have cause blown AM2 fuse (15amp), if your car won't turn on at all...
    Check AM2 fuse, don't replace it until you replace inverter pump..
    Don Shouse, bisco and edthefox5 like this.
